Ga door naar hoofdinhoud
HKC P776A Battery Replacement
Wat je nodig hebt
  1. HKC P776A Battery Replacement, Separating Digitizer and Case: stap 1, afbeelding 1 van 1
    • Insert the plastic opening tool between the digitizer and the case.
    • Place the spudger in the gap created by the plastic opening tool to assist in separation.
  2. HKC P776A Battery Replacement: stap 2, afbeelding 1 van 2 HKC P776A Battery Replacement: stap 2, afbeelding 2 van 2
    • Slide the spudger along the perimeter of the device to fully separate the two pieces.
  3. HKC P776A Battery Replacement, Battery: stap 3, afbeelding 1 van 1
    • Insert the plastic opening tool between the battery and case.
    • Apply leverage to break the glue that is attaching the battery to the case.
  4. HKC P776A Battery Replacement: stap 4, afbeelding 1 van 1
    • Continue breaking the glue along the perimeter of the battery until the battery can be removed.
    • Breaking all the glue between the battery and case may take a long time.
  5. HKC P776A Battery Replacement: stap 5, afbeelding 1 van 2 HKC P776A Battery Replacement: stap 5, afbeelding 2 van 2
    • Using the soldering iron, heat up the solder that is attaching the battery to the motheboard.
    • The heat from the soldering iron may cause personal injury or damage the internal components of the tablet.
  6. HKC P776A Battery Replacement: stap 6, afbeelding 1 van 1
    • Suck up the leftover solder using the desoldering pump.
    • Remove the battery from the motherboard.
Conclusie
Ryan Gornati
409 Reputatie
4 handleidingen geschreven
USF Tampa, Team 7-6, Remmell Winter 2015 Lid van USF Tampa, Team 7-6, Remmell Winter 2015
USFT-REMMELL-W15S7G6
3 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 636
