Ga door naar hoofdinhoud
HKC P774A Camera Replacement
Wat je nodig hebt
  1. HKC P774A Camera Replacement, Digitizer: stap 1, afbeelding 1 van 3 HKC P774A Camera Replacement, Digitizer: stap 1, afbeelding 2 van 3 HKC P774A Camera Replacement, Digitizer: stap 1, afbeelding 3 van 3
    • Insert the flat end of the spudger into the side of the device
    • This will create a gap between the device and screen housing.
    • Insert the plastic opening tool into this gap and move it along this gap.
    • Make sure not to bent the digitizer during this step.
    • The screen housing and device will now be separated.
  2. HKC P774A Camera Replacement: stap 2, afbeelding 1 van 3 HKC P774A Camera Replacement: stap 2, afbeelding 2 van 3 HKC P774A Camera Replacement: stap 2, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Once the digitizer has been been removed from the body, disconnect the digitizer band from the motherboard.
    • Two small black pins (circled in red) will need to be unlocked.
    • Unlock the pins by pulling them outward with the tweezers.
    • Make sure the pins are released entirely before attempting to remove the band.
    • Remove the band using the tweezers.
  3. HKC P774A Camera Replacement: stap 3, afbeelding 1 van 3 HKC P774A Camera Replacement: stap 3, afbeelding 2 van 3 HKC P774A Camera Replacement: stap 3, afbeelding 3 van 3
    • Once the digitizer has been disconnected from the motherboard, the LCD screen must be removed from the digitizer.
    • Push open the tabs (circled in red) using the flat end of the plastic spudger.
    • Be sure not to bend the digitizer while prying.
    • Continue to release all tabs while continuing to pry the LCD away from the digitizer.
  4. HKC P774A Camera Replacement, Camera: stap 4, afbeelding 1 van 3 HKC P774A Camera Replacement, Camera: stap 4, afbeelding 2 van 3 HKC P774A Camera Replacement, Camera: stap 4, afbeelding 3 van 3
    Koop
    • Use the tweezers to pull out the black pins (circled in red).
    • Use the tweezers to remove the camera band from the motherboard.
    • Handle the band with care.
  5. HKC P774A Camera Replacement: stap 5, afbeelding 1 van 3 HKC P774A Camera Replacement: stap 5, afbeelding 2 van 3 HKC P774A Camera Replacement: stap 5, afbeelding 3 van 3
    • Use the flat end of the plastic spudger to pry the camera lens from the case.
    • Use the tweezers to remove the camera and band.
Conclusie
Sean McCauley
512 Reputatie
4 handleidingen geschreven
Montana Tech, Team 10-1, Shirk Fall 2015 Lid van Montana Tech, Team 10-1, Shirk Fall 2015
MTUM-SHIRK-F15S10G1
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 4
Altijd: 71
