Ga door naar hoofdinhoud
HKC P771A Camera Replacement
Wat je nodig hebt
  1. HKC P771A Camera Replacement, Camera: stap 1, afbeelding 1 van 3 HKC P771A Camera Replacement, Camera: stap 1, afbeelding 2 van 3 HKC P771A Camera Replacement, Camera: stap 1, afbeelding 3 van 3
    • Remove back of tablet using the plastic opening tool
    • Slide the opening tool between the back of the tablet and the digitizer
    • Lift along the edges until the back of the tablet and the digitizer are separated
  2. HKC P771A Camera Replacement: stap 2, afbeelding 1 van 2 HKC P771A Camera Replacement: stap 2, afbeelding 2 van 2
    • Remove yellow tape around the edges of the battery
    • The battery is located on the right side of the tablet when the screen is facing downwards and the camera is on top
  3. HKC P771A Camera Replacement: stap 3, afbeelding 1 van 3 HKC P771A Camera Replacement: stap 3, afbeelding 2 van 3 HKC P771A Camera Replacement: stap 3, afbeelding 3 van 3
    • Pry battery away from the back of the tablet until the battery is completely separated from the adhesive
  4. HKC P771A Camera Replacement: stap 4, afbeelding 1 van 1
    • Remove yellow tape that is securing the camera wires
  5. HKC P771A Camera Replacement: stap 5, afbeelding 1 van 2 HKC P771A Camera Replacement: stap 5, afbeelding 2 van 2
    • Remove silver foil from the back of the camera using the blue opening tool
  6. HKC P771A Camera Replacement: stap 6, afbeelding 1 van 1
    • Lift the bronze, L-shaped ribbon
    • The camera is attached to the end of this ribbon so it will move with it
  7. HKC P771A Camera Replacement: stap 7, afbeelding 1 van 1
    • Flip up the black bar located on the motherboard
    • The black bar is to the left of the camera, where the ribbon is attached to the motherboard
  8. HKC P771A Camera Replacement: stap 8, afbeelding 1 van 1
    • Remove the bronze, L-shaped ribbon from inside the black bar
  9. HKC P771A Camera Replacement: stap 9, afbeelding 1 van 1
    • Your camera is now removed from the tablet
Conclusie
Sara Hill
101 Reputatie
2 handleidingen geschreven
Ohio State, Team 2-3, Garvin Fall 2015 Lid van Ohio State, Team 2-3, Garvin Fall 2015
OSU-GARVIN-F15S2G3
4 Leden
4 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 226
