Ga door naar hoofdinhoud
HAMILTON C-1 Preventative Maintenance for Air, Fan, and HEPA Filters Replacement
Medische apparatuur
Noch iFixit, noch deze reparatiehandleiding worden onderschreven door of zijn gelieerd aan de fabrikant van de desbetreffende medische apparatuur.
Wat je nodig hebt
  1. HAMILTON C-1 Preventative Maintenance for Air, Fan, and HEPA Filters Replacement, Air Filter: stap 1, afbeelding 1 van 2 HAMILTON C-1 Preventative Maintenance for Air, Fan, and HEPA Filters Replacement, Air Filter: stap 1, afbeelding 2 van 2
    • Turn the Hamilton-C1 so that the rear view of the device is facing you.
    • Use your fingers to grasp the current air filter located at number 4 of the graphic and pull the filter out of the slot.
  2. HAMILTON C-1 Preventative Maintenance for Air, Fan, and HEPA Filters Replacement: stap 2, afbeelding 1 van 1
    • Insert a new air filter into the slot located at number 4.
  3. HAMILTON C-1 Preventative Maintenance for Air, Fan, and HEPA Filters Replacement, Fan Filter: stap 3, afbeelding 1 van 2 HAMILTON C-1 Preventative Maintenance for Air, Fan, and HEPA Filters Replacement, Fan Filter: stap 3, afbeelding 2 van 2
    • Orient the Hamilton-C1 to the right side so that the gas connections are visible.
    • Grab and remove the fan filter located at location number 5 in the graphic.
  4. HAMILTON C-1 Preventative Maintenance for Air, Fan, and HEPA Filters Replacement: stap 4, afbeelding 1 van 1
    • Place a new fan filter into the designated slot.
  5. HAMILTON C-1 Preventative Maintenance for Air, Fan, and HEPA Filters Replacement, HEPA Filter: stap 5, afbeelding 1 van 2 HAMILTON C-1 Preventative Maintenance for Air, Fan, and HEPA Filters Replacement, HEPA Filter: stap 5, afbeelding 2 van 2
    • Orient the Hamilton-C1 so the back is facing you.
    • Remove the back panel as labeled by number 6 of the graphic using a Phillips #1 screwdriver.
  6. HAMILTON C-1 Preventative Maintenance for Air, Fan, and HEPA Filters Replacement: stap 6, afbeelding 1 van 1
    • Remove the current HEPA filter by pulling the filter outward and down.
    • Insert the new HEPA filter into the slot.
Conclusie
Tina Vo
538 Reputatie
4 handleidingen geschreven
Cal Poly, Team S7-G11, Paton Spring 2020 Lid van Cal Poly, Team S7-G11, Paton Spring 2020
CPSU-PATON-S20S7G11
2 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 16
Altijd: 346
