Inleiding
This guide will help you prepare your printer for it’s first print. It is important to verify the steppers, end stops, and heaters are working correctly before you a attempt to start your first calibration print.
This guide is still a work in progress. Pictures and additional info will be added over the coming weeks
Hotend and bed sensor should be reading around room temperature
If either sensor shows a "-###c"(negative temperature) double check your your connections. It's common to show this if you don't have a good connection.
Vin is your PSU input voltage
V12 is the Duets on board 12v regulator
MCU temperature is the Duets processor temperature
