Inleiding
This guide will demonstrate how to clean or replace the strummer (strum bar) for a Guitar Hero: World Tour Controller.
The strummer can often become sluggish or stuck from wear and tear over time. This can often be solved by simply cleaning or lubricating the strum bar, or by replacing it entirely if damaged.
Two AA batteries will need to be removed as shown in the guide.
Wat je nodig hebt
Remove four Phillips #0 screws holding the strum bar assembly.
Remove the strum bar assembly from the body. Ensure that both springs are present and in good condition.
Check the joint between the strum bar and its mounting brackets. Ensure there are no foreign objects jamming the hole. Ensure the joint is well lubricated.
3 andere personen hebben deze handleiding voltooid.
4 opmerkingen
Great guide! Helped me find some loose screws that fixed the strumming when tightened.
Only note is that my controller uses Torx T6 screws instead of Phillips #0 screws. From info online, it looks like these controllers can have either type.
Yes, The RedOctane (95457.805) edition has no Phillips #0 screws, but but T6 size screws so this may be an edition or region difference? This RedOctane wireless one is in EU region.
How much difference is there between this and a guitar hero 5 guitar ? Having an issue when I strum up the strum bar sticks and doesn’t return to center not sure if it’s an issue with friction or the switches are bad
Hey can anyone help me was playing guitar hero world tour just fine but today my guitar will not strum up or down on the game but move just fine on my xbox 360 dashboard.i just don't get it
