Ga door naar hoofdinhoud
Grip Tape Application
Wat je nodig hebt
  1. Grip Tape Application, Grip Tape Application: stap 1, afbeelding 1 van 1
    • Peel off the paper backing from the sheet of grip tape.
    • Make sure you do not fold or wrinkle the grip tape.
  2. Grip Tape Application: stap 2, afbeelding 1 van 1
    • Center the sheet of grip tape evenly over the top of the skateboard deck.
  3. Grip Tape Application: stap 3, afbeelding 1 van 2 Grip Tape Application: stap 3, afbeelding 2 van 2
    • Starting from the very middle and moving outward, firmly press down on the grip tape while smoothing out any air bubbles that start to form.
  4. Grip Tape Application: stap 4, afbeelding 1 van 2 Grip Tape Application: stap 4, afbeelding 2 van 2
    • Use a screwdriver to scrape along the edges of the skateboard. This will remove some of the grip around the edges making the trimming process easier on you and your equipment.
    • You can use the utility knife to cut a perpendicular line in the excess grip tape if it is resisting the screwdriver too much.
  5. Grip Tape Application: stap 5, afbeelding 1 van 3 Grip Tape Application: stap 5, afbeelding 2 van 3 Grip Tape Application: stap 5, afbeelding 3 van 3
    • Use a utility knife to begin cutting around the edge of your skateboard to remove excess grip tape.
    • Angle your knife towards the inside of the skateboard to make it easier to cut a straight line.
    • Be careful when using the utility knife and always keep it pointed away from yourself and others.
  6. Grip Tape Application: stap 6, afbeelding 1 van 1
    • Once you have removed all of the excess grip tape, you can use the scraps to sand the edges of your cut to smooth out any small inconsistencies.
    • Use caution when sanding as the grip tape can become heated.
  7. Grip Tape Application: stap 7, afbeelding 1 van 1
    • If air bubbles persist, gently use a utility knife to poke a small hole in the grip tape at the center of the bubble and press out the air.
  8. Grip Tape Application: stap 8, afbeelding 1 van 2 Grip Tape Application: stap 8, afbeelding 2 van 2
    • After you have finished applying your grip tape, you can use a small screwdriver to poke holes where your truck hardware will be installed.
    What if the grip tape that already on my board is damaged how do I replace it. The board is old but I don't want to replace it
    Zeth - Antwoord
    What if the tape on my board I damaged how do I replace it? The boards old but I don't want to get rid of it.
    Zeth - Antwoord
Conclusie
The next logical step in the assembly of a skateboard is to install skateboard trucks, please reference the Truck Installation guide.
4 andere personen hebben deze handleiding voltooid.
Jared Stine
800 Reputatie
3 handleidingen geschreven
Cal Poly, Team 6-32, Regan Fall 2012 Lid van Cal Poly, Team 6-32, Regan Fall 2012
CPSU-REGAN-F12S6G32
5 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 7
Altijd: 7,948
