Inleiding
This guide will teach the user how to install the left side panel and align the "mode" button correctly. It will also show the proper placement of the button to restore the device to its retail form.
Onderdelen
Geen onderdelen nodig.
  1. Lodge the tip of the plastic opening tool into the top arc of the front panel. Apply a little force to cause the panel to detach.
    • Lodge the tip of the plastic opening tool into the top arc of the front panel. Apply a little force to cause the panel to detach.
  2. Slide the blue opening tool along the seam applying force to continue detaching the side panel. Remove the button from the side panel. Remove the button from the side panel.
    • Slide the blue opening tool along the seam applying force to continue detaching the side panel.
    • Remove the button from the side panel.
  3. Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
    Doorblader onze winkel
    Ooit iets gerepareerd? Je bent een genie.
    Deel je reparatie met #ImAGenius
    We zijn allemaal genieën
  4. Ensure that the elevated grating is on the right side of the button in respect to the panel position seen in the first image. Insert the button into the side panel's designated slot using your fingers or tweezers if necessary.
    • Ensure that the elevated grating is on the right side of the button in respect to the panel position seen in the first image.
    • Insert the button into the side panel's designated slot using your fingers or tweezers if necessary.
  5. Insert the top arc of the side panel into the top end of the device's side as seen in the second image. Insert the top arc of the side panel into the top end of the device's side as seen in the second image.
    • Insert the top arc of the side panel into the top end of the device's side as seen in the second image.
  6. Push the bottom end of the panel into the panel slot and apply additional pressure to the side panel to ensure it is attached to the device securely. Push the bottom end of the panel into the panel slot and apply additional pressure to the side panel to ensure it is attached to the device securely.
    • Push the bottom end of the panel into the panel slot and apply additional pressure to the side panel to ensure it is attached to the device securely.
Conclusie
After installation, the device should look similar to that which is depicted in the cover image (top right of page).
Alexander
101 Reputatie
9 handleidingen geschreven
Clemson, Team 15-3, Benson Spring 2012 Lid van Clemson, Team 15-3, Benson Spring 2012
CLEM-BENSON-S12S15G3
3 Leden
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 884
