Inleiding
This guide will teach you how to remove the circuit board from the device. This will allow the simple installation of the LCD screen cover.
Onderdelen
Geen onderdelen nodig.
  1. Lodge the tip of the plastic opening tool into the top arc of the front panel. Apply a little force to cause the panel to detach.
    • Lodge the tip of the plastic opening tool into the top arc of the front panel. Apply a little force to cause the panel to detach.
  2. Slide the blue opening tool along the seam applying force to continue detaching the side panel. Remove the button from the side panel. Remove the button from the side panel.
    • Slide the blue opening tool along the seam applying force to continue detaching the side panel.
    • Remove the button from the side panel.
  3. Use the plastic opening tool.
    • Use the plastic opening tool.
    • Lodge the tip into the corner of the device; Applying pressure upward, allowing the panel to be released.
  4. Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  5. The side panel can now be detached using your fingers. The buttons can be dislodged by turning the panel over and shaking it, if necessary. The buttons can be dislodged by turning the panel over and shaking it, if necessary.
    • The side panel can now be detached using your fingers.
    • The buttons can be dislodged by turning the panel over and shaking it, if necessary.
  6. The central button can easily be removed by using your fingers or tweezers to push the button out towards the left panel. The central button can easily be removed by using your fingers or tweezers to push the button out towards the left panel.
    • The central button can easily be removed by using your fingers or tweezers to push the button out towards the left panel.
  7. Carefully remove the circuit board/LCD component from the device by pulling it towards the left open panel. Carefully remove the circuit board/LCD component from the device by pulling it towards the left open panel.
    • Carefully remove the circuit board/LCD component from the device by pulling it towards the left open panel.
  8. The screen cover can be easily lifted and removed from the LCD screen.
    • The screen cover can be easily lifted and removed from the LCD screen.
  9. Place the screen cover on top of the LCD so it covers its entirety and carefully slide the circuit board/LCD back into the device. Place the screen cover on top of the LCD so it covers its entirety and carefully slide the circuit board/LCD back into the device.
    • Place the screen cover on top of the LCD so it covers its entirety and carefully slide the circuit board/LCD back into the device.
Conclusie
After installation, the device should look similar to that which is depicted in the cover image (top right of page).
Alexander
101 Reputatie
9 handleidingen geschreven
Clemson, Team 15-3, Benson Spring 2012 Lid van Clemson, Team 15-3, Benson Spring 2012
CLEM-BENSON-S12S15G3
3 Leden
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 1
Altijd: 905
