Ga door naar hoofdinhoud
Grand Neo Plus - Hard Reset, Test Menu, Safe Mode, Developer Options, Secret Codes
Video overzicht
  1. Grand Neo Plus - Hard Reset, Test Menu, Safe Mode, Developer Options, Secret Codes, HARD RESET: stap 1, afbeelding 1 van 3 Grand Neo Plus - Hard Reset, Test Menu, Safe Mode, Developer Options, Secret Codes, HARD RESET: stap 1, afbeelding 2 van 3 Grand Neo Plus - Hard Reset, Test Menu, Safe Mode, Developer Options, Secret Codes, HARD RESET: stap 1, afbeelding 3 van 3
    • Attention!!! This will erase all your personal information (address book, accounts, messages, etc.) and will set the settings to its original state.
    • Switch off the phone.
    • Press and hold Volume Up, Home and Power buttons for a long time (15-20 sec.).
    • When you see the Galaxy logo release the buttons.
    • To navigate through the Android System Recovery menu, use the Volume up/down buttons to scroll up and down and the Power button to confirm selections. Select:
    • - wipe data/factory reset
    • - Yes -- delete all user data
    • - reboot system now.
  2. Grand Neo Plus - Hard Reset, Test Menu, Safe Mode, Developer Options, Secret Codes, SERVICE TEST MENU: stap 2, afbeelding 1 van 3 Grand Neo Plus - Hard Reset, Test Menu, Safe Mode, Developer Options, Secret Codes, SERVICE TEST MENU: stap 2, afbeelding 2 van 3 Grand Neo Plus - Hard Reset, Test Menu, Safe Mode, Developer Options, Secret Codes, SERVICE TEST MENU: stap 2, afbeelding 3 van 3
    • Hidden Test Menu - lets you troubleshoot hardware issues and check your phone's functionality.
    • • Method One: Use this code *#0*# to enter the phone into the test menu.
    • • Method Two: From the deal app enter *#7353#
    • From this menu you can run tests for vibration, RGB colors, touch-screen, vibration, loudspeaker output, camera, sensor check and so on.
  3. Grand Neo Plus - Hard Reset, Test Menu, Safe Mode, Developer Options, Secret Codes, SECRET CODES: stap 3, afbeelding 1 van 3 Grand Neo Plus - Hard Reset, Test Menu, Safe Mode, Developer Options, Secret Codes, SECRET CODES: stap 3, afbeelding 2 van 3 Grand Neo Plus - Hard Reset, Test Menu, Safe Mode, Developer Options, Secret Codes, SECRET CODES: stap 3, afbeelding 3 van 3
    • Secret Codes - one of the most important uses of these codes are to get information about your products and troubleshoot common problems.
    • *#06# - IMEI number
    • *#1234# - Firmware version
    • *#2222# - Hardware version
    • *#0011# - GSM network status
    • *#0228# - Battery status
    • *#7353# - Self test menu
    • *#1111# - FTA SW version
  4. Grand Neo Plus - Hard Reset, Test Menu, Safe Mode, Developer Options, Secret Codes, SAFE MODE: stap 4, afbeelding 1 van 2 Grand Neo Plus - Hard Reset, Test Menu, Safe Mode, Developer Options, Secret Codes, SAFE MODE: stap 4, afbeelding 2 van 2
    • General Safe Mode - If your device hang, freezes randomly, restarts, become slow over time, battery drain so quickly and any other issue then you can boot your device into the safe mode. In this mode the OS temporally turns off all user-installed apps.
    • Press and hold the Volume Down and the Power buttons.
    • When you see the Galaxy logo, release only the Power button
    • Now all third-party apps (apps that are installed by you) are disabled.
    • To exit Safe mode just tap on the Safe mode notification or restart the device manually.
  5. Grand Neo Plus - Hard Reset, Test Menu, Safe Mode, Developer Options, Secret Codes, DEVELOPER OPTIONS: stap 5, afbeelding 1 van 3 Grand Neo Plus - Hard Reset, Test Menu, Safe Mode, Developer Options, Secret Codes, DEVELOPER OPTIONS: stap 5, afbeelding 2 van 3 Grand Neo Plus - Hard Reset, Test Menu, Safe Mode, Developer Options, Secret Codes, DEVELOPER OPTIONS: stap 5, afbeelding 3 van 3
    • Developer options - give you access to ADB settings, USB debugging, and various monitoring tools for your device. It's also the one of the first steps to rooting your device.
    • Go to - Menu - Settings - About device, Scroll down to Build number, and tap it seven times.
    • Do not change the options if you do not know what you're doing.
    • That's all.
    • Did you do it successfully?
Conclusie
51 andere personen hebben deze handleiding voltooid.
ZFix
191.882 Reputatie
330 handleidingen geschreven
Master Techs Lid van Master Techs
Community
321 Leden
1.516 handleidingen geschreven
12 opmerkingen
I can't get 2 my menu,because of safemode and forgotten password! Plse hlp
noah - Antwoord
thanks for this web page, its very help full for me be cause my cell phone cannot boot properly due,
now it is working properly
thanks
mansoor
Ali Ahmad - Antwoord
Tried to just reboot, even factory reset still stuck in safe mode
Steve Muto - Antwoord
You might be have issue with your up-down volume button. Once you get fix the issue, your device will back normally.
kaingkaing20 -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 97
Altijd: 71,129
