Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Inleiding
Follow this guide to clean out a clogged—or replace a damaged—filter in the spray gun for the Graco Paint Sprayer 17C325.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
  1. Before you begin, make sure to follow the pressure relief procedure documented in the user manual before disconnecting and disassembling the spray gun. Unscrew and remove the handle from the spray gun body. You may need to use a pipe wrench to loosen the handle before removing it.
    • Before you begin, make sure to follow the pressure relief procedure documented in the user manual before disconnecting and disassembling the spray gun.
    • Unscrew and remove the handle from the spray gun body.
    • You may need to use a pipe wrench to loosen the handle before removing it.
  2. Nintendo Switch-kits
    Een snelle oplossing die je weer mee laat doen
    Koop Switchkits
    Koop Switchkits
  3. Use your fingers to remove the blue-tipped filter from the inside of the handle. Use your fingers to remove the blue-tipped filter from the inside of the handle. Use your fingers to remove the blue-tipped filter from the inside of the handle.
    • Use your fingers to remove the blue-tipped filter from the inside of the handle.
Conclusie
Craig Lloyd
8.748 Reputatie
47 handleidingen geschreven
iFixit Lid van iFixit
Community
119 Leden
11.532 handleidingen geschreven
Één commentaar
It would be beneficial to have the part numbers in this information as well! Otherwise, great job! Thanks
JANET - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 28
Altijd: 67
