Ga door naar hoofdinhoud
Google Pixelbook Go Left Charging Port Replacement
Wat je nodig hebt
  1. Google Pixelbook Go Left Charging Port Replacement, Back Panel: stap 1, afbeelding 1 van 2 Google Pixelbook Go Left Charging Port Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Flip the device so that the back is facing up.
    • Peel the rubber stoppers off the top and bottom of the device.
  2. Google Pixelbook Go Left Charging Port Replacement: stap 2, afbeelding 1 van 2 Google Pixelbook Go Left Charging Port Replacement: stap 2, afbeelding 2 van 2
    • Remove ten 3 mm screws from around the edge of the back panel using a T5 Torx screwdriver.
  3. Google Pixelbook Go Left Charging Port Replacement: stap 3, afbeelding 1 van 3 Google Pixelbook Go Left Charging Port Replacement: stap 3, afbeelding 2 van 3 Google Pixelbook Go Left Charging Port Replacement: stap 3, afbeelding 3 van 3
    • Use an iFixit opening tool to pry up the back panel cover.
    • There is an orange ribbon cable that connects the cover to the base, so don't separate the two pieces completely.
    • Remove the single 2 mm screw using a Torx T3 screwdriver.
    • Disconnect the orange cable from the base of the device.
  4. Google Pixelbook Go Left Charging Port Replacement: stap 4, afbeelding 1 van 1
    • Insert wisdom here.
  5. Google Pixelbook Go Left Charging Port Replacement, Left Charging Port: stap 5, afbeelding 1 van 1
    • Find the left side of the device by locating the white stickers
    • Remove the three pink screws using a T3 Torx screwdriver.
  6. Google Pixelbook Go Left Charging Port Replacement: stap 6, afbeelding 1 van 2 Google Pixelbook Go Left Charging Port Replacement: stap 6, afbeelding 2 van 2
    • Carefully grab the silver tab and slide the left charging port out of the laptop.
Conclusie
Harleen Chahal
85 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 24
Altijd: 164
