Ga door naar hoofdinhoud
Google Pixel Slate Speaker Replacement
Wat je nodig hebt
  1. Google Pixel Slate Speaker Replacement, Screen: stap 1, afbeelding 1 van 3 Google Pixel Slate Speaker Replacement, Screen: stap 1, afbeelding 2 van 3 Google Pixel Slate Speaker Replacement, Screen: stap 1, afbeelding 3 van 3
    • Orient the Google Pixel Slate so that the screen is facing upwards.
    • Use the iFixit opening tool to separate screen from main body.
    • Use the suction cup to remove the screen from the body of the device.
  2. Google Pixel Slate Speaker Replacement: stap 2, afbeelding 1 van 3 Google Pixel Slate Speaker Replacement: stap 2, afbeelding 2 van 3 Google Pixel Slate Speaker Replacement: stap 2, afbeelding 3 van 3
    • Gently disconnect the three flat-wires from the screen.
    • Carefully separate and remove the screen from the body of the device.
  3. Google Pixel Slate Speaker Replacement, Speaker: stap 3, afbeelding 1 van 3 Google Pixel Slate Speaker Replacement, Speaker: stap 3, afbeelding 2 van 3 Google Pixel Slate Speaker Replacement, Speaker: stap 3, afbeelding 3 van 3
    • There are two speakers, one on each side of the Google Pixel Slate. This guide works for either one.
    • Use the T2 Torx screwdriver to remove the yellow 2mm screw from the thin metal plate.
    • Use the T3 Torx screwdriver to remove the pink 3mm screw from the thin metal plate.
    • Remove the thin metal plate from the device.
  4. Google Pixel Slate Speaker Replacement: stap 4, afbeelding 1 van 1
    • Use the T2 Torx screwdriver to remove the two black 2mm screws from the speaker.
  5. Google Pixel Slate Speaker Replacement: stap 5, afbeelding 1 van 2 Google Pixel Slate Speaker Replacement: stap 5, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Use the Nylon-Tipped Tweezers to remove the black plug.
    • There is a red and a black wire connected to the black plug.
    • Pull the black plug in an upwards direction.
    • Be sure to gently remove plug, as using too much force can damage the connecting wires.
  6. Google Pixel Slate Speaker Replacement: stap 6, afbeelding 1 van 2 Google Pixel Slate Speaker Replacement: stap 6, afbeelding 2 van 2
    • Use the Nylon-Tipped Tweezers to disconnect the black tape-like plug connected to the speaker.
  7. Google Pixel Slate Speaker Replacement: stap 7, afbeelding 1 van 2 Google Pixel Slate Speaker Replacement: stap 7, afbeelding 2 van 2
    • Detach the speaker wire from the motherboard.
    • Remove the adhesive strips that hold down the speaker wire.
  8. Google Pixel Slate Speaker Replacement: stap 8, afbeelding 1 van 3 Google Pixel Slate Speaker Replacement: stap 8, afbeelding 2 van 3 Google Pixel Slate Speaker Replacement: stap 8, afbeelding 3 van 3
    • Use the T2 Torx screwdriver to remove the 2mm black screw from the brass plate.
    • Pull back the brass plate.
  9. Google Pixel Slate Speaker Replacement: stap 9, afbeelding 1 van 1
    • You can now remove the speaker from the device.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Spencer Alonge
648 Reputatie
5 handleidingen geschreven
Cal Poly, Team S2-G5, Maness Spring 2019 Lid van Cal Poly, Team S2-G5, Maness Spring 2019
CPSU-MANESS-S19S2G5
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 23
Altijd: 912
