Ga door naar hoofdinhoud
Google Pixel Slate Screen Replacement
Wat je nodig hebt
  1. Google Pixel Slate Screen Replacement, Screen: stap 1, afbeelding 1 van 3 Google Pixel Slate Screen Replacement, Screen: stap 1, afbeelding 2 van 3 Google Pixel Slate Screen Replacement, Screen: stap 1, afbeelding 3 van 3
    • Orient the Google Pixel Slate so that the screen is facing upwards.
    • Use the iFixit opening tool to separate screen from main body. The screen is held down by adhesive, you will need to use the iOpener or a heat gun/ hairdryer to soften it. Failure to do this will result in a broken screen.
    • Use the suction cup to remove the screen from the body of the device.
  2. Google Pixel Slate Screen Replacement: stap 2, afbeelding 1 van 3 Google Pixel Slate Screen Replacement: stap 2, afbeelding 2 van 3 Google Pixel Slate Screen Replacement: stap 2, afbeelding 3 van 3
    • Gently disconnect the three flat-wires from the screen.
    • Carefully separate and remove the screen from the body of the device.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Spencer Alonge
678 Reputatie
5 handleidingen geschreven
Cal Poly, Team S2-G5, Maness Spring 2019 Lid van Cal Poly, Team S2-G5, Maness Spring 2019
CPSU-MANESS-S19S2G5
4 Leden
13Gids Commentaar
Where did you source the replacement screen? Can we get a link added to the parts list?
Brandon Price - Antwoord
Anyone know where to source the replacement screen? Any help would be greatly appreciated.
Yeah, I could use the replacement source as well. Thanks.
Benjamin Reese - Antwoord
me too! the resource replacement link plz!!
gabriela urquidi - Antwoord
Is the screen held down with adhesive or does it have any clips? Also, does anyone know where I could source any Pixel Slate parts?
Kevin Freyre - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 81
Altijd: 5,603
