Ga door naar hoofdinhoud
Google Pixel Slate Front-Facing Camera Replacement
Wat je nodig hebt
  1. Google Pixel Slate Front-Facing Camera Replacement, Screen: stap 1, afbeelding 1 van 3 Google Pixel Slate Front-Facing Camera Replacement, Screen: stap 1, afbeelding 2 van 3 Google Pixel Slate Front-Facing Camera Replacement, Screen: stap 1, afbeelding 3 van 3
    • Orient the Google Pixel Slate so that the screen is facing upwards.
    • Use the iFixit opening tool to separate screen from main body.
    • Use the suction cup to remove the screen from the body of the device.
  2. Google Pixel Slate Front-Facing Camera Replacement: stap 2, afbeelding 1 van 3 Google Pixel Slate Front-Facing Camera Replacement: stap 2, afbeelding 2 van 3 Google Pixel Slate Front-Facing Camera Replacement: stap 2, afbeelding 3 van 3
    • Gently disconnect the three flat-wires from the screen.
    • Carefully separate and remove the screen from the body of the device.
  3. Google Pixel Slate Front-Facing Camera Replacement, Front-Facing Camera: stap 3, afbeelding 1 van 3 Google Pixel Slate Front-Facing Camera Replacement, Front-Facing Camera: stap 3, afbeelding 2 van 3 Google Pixel Slate Front-Facing Camera Replacement, Front-Facing Camera: stap 3, afbeelding 3 van 3
    • Once removed, place the screen face down.
    • Peel back the black, adhesive strip covering the front camera so that the silver plate is exposed.
  4. Google Pixel Slate Front-Facing Camera Replacement: stap 4, afbeelding 1 van 3 Google Pixel Slate Front-Facing Camera Replacement: stap 4, afbeelding 2 van 3 Google Pixel Slate Front-Facing Camera Replacement: stap 4, afbeelding 3 van 3
    • Hold back the adhesive tape to expose the two black 2mm screws that are holding down the cover plate.
    • Use the T2 Torx screwdriver to remove the two 2mm screws.
  5. Google Pixel Slate Front-Facing Camera Replacement: stap 5, afbeelding 1 van 2 Google Pixel Slate Front-Facing Camera Replacement: stap 5, afbeelding 2 van 2
    • Once the two 2mm screws are removed, lift and remove the cover plate.
  6. Google Pixel Slate Front-Facing Camera Replacement: stap 6, afbeelding 1 van 2 Google Pixel Slate Front-Facing Camera Replacement: stap 6, afbeelding 2 van 2
    • Pull upwards on the flat wire to remove the front-facing camera from the device.
    • The camera may be secured to the screen body with adhesive tape. Apply gentle force to remove the camera by removing the tape.
Conclusie
Spencer Alonge
663 Reputatie
5 handleidingen geschreven
Cal Poly, Team S2-G5, Maness Spring 2019 Lid van Cal Poly, Team S2-G5, Maness Spring 2019
CPSU-MANESS-S19S2G5
4 Leden
1Gids Commentaar
Do you offer the cable that runs from the camera to the tablet motherboard or the front facing camera with cable?
Heidi Hose - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 895
