Ga door naar hoofdinhoud
Google Pixel 4a Screen Replacement
Wat je nodig hebt
  1. Google Pixel 4a Screen Replacement, Precautionary notes: stap 1, afbeelding 1 van 3 Google Pixel 4a Screen Replacement, Precautionary notes: stap 1, afbeelding 2 van 3 Google Pixel 4a Screen Replacement, Precautionary notes: stap 1, afbeelding 3 van 3
    • You will need to pry the screen up to remove it from the phone. Read the following notes carefully before proceeding.
    • Take note of the two seams on the edge of the phone:
    • Screen seam: This seam separates the screen from the rest of the phone. This is where you should pry.
    • Frame seam: This is where the plastic frame meets the back cover. It is held in place by screws. Do not pry at this seam.
    • Before you begin, note the following areas on the screen:
    • Screen flex cable: Do not insert the opening pick deeper than instructed or you risk damaging this cable.
    • Adhesive perimeter: Prying beyond this narrow perimeter without angling the pick will damage the OLED panel.
  2. Google Pixel 4a Screen Replacement, Heat the right edge of the screen: stap 2, afbeelding 1 van 1
    • Apply a heated iOpener to the right edge of the display for one minute to soften the adhesive.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  3. Google Pixel 4a Screen Replacement, Insert an opening pick: stap 3, afbeelding 1 van 3 Google Pixel 4a Screen Replacement, Insert an opening pick: stap 3, afbeelding 2 van 3 Google Pixel 4a Screen Replacement, Insert an opening pick: stap 3, afbeelding 3 van 3
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Place a suction cup as close to the right edge of the screen as possible.
    • Lift the suction cup with a strong steady force.
    • Insert the tip of an opening pick into the screen seam no more than 1 mm.
  4. Google Pixel 4a Screen Replacement, Guide the opening pick under the OLED panel: stap 4, afbeelding 1 van 3 Google Pixel 4a Screen Replacement, Guide the opening pick under the OLED panel: stap 4, afbeelding 2 van 3 Google Pixel 4a Screen Replacement, Guide the opening pick under the OLED panel: stap 4, afbeelding 3 van 3
    • This step shows how to insert the pick without damaging the OLED panel. Do this before beginning to slice the adhesive.
    • With the pick 1 mm into the gap, pivot the pick upwards to a steep angle.
    • At a steep angle, carefully push the pick into the gap about 1/4 inch (6 mm). The pick should slide in below the OLED panel.
    • Stop if you feel the point of the pick hitting a ridge. The pick may be pressing against the edge of the OLED panel. Angle the pick and try again.
  5. Google Pixel 4a Screen Replacement, Cut the adhesive: stap 5, afbeelding 1 van 3 Google Pixel 4a Screen Replacement, Cut the adhesive: stap 5, afbeelding 2 van 3 Google Pixel 4a Screen Replacement, Cut the adhesive: stap 5, afbeelding 3 van 3
    • Slide the pick along the right edge of the screen to cut the adhesive.
    • Do not insert the pick more than 1/4 inch (6 mm) or you may damage the screen's flex cable.
    • Leave the pick in the top right corner to prevent the adhesive from re-sealing.
  6. Google Pixel 4a Screen Replacement: stap 6, afbeelding 1 van 3 Google Pixel 4a Screen Replacement: stap 6, afbeelding 2 van 3 Google Pixel 4a Screen Replacement: stap 6, afbeelding 3 van 3
    • The screen adhesive is very weak and you should not need to re-apply heat. If the screen does feel hard to slice, apply heat to the difficult area for one minute and try again.
    • Insert another opening pick into the right edge of the phone at an angle where a gap has already formed to prevent damage to the OLED panel.
    • Slide the opening pick around the bottom of the phone to cut the adhesive.
    • Leave the pick inserted along the bottom edge to prevent the adhesive from resealing.
  7. Google Pixel 4a Screen Replacement: stap 7, afbeelding 1 van 3 Google Pixel 4a Screen Replacement: stap 7, afbeelding 2 van 3 Google Pixel 4a Screen Replacement: stap 7, afbeelding 3 van 3
    • Insert another opening pick into the bottom edge of the phone at an angle where a gap has already formed to prevent damage to the OLED panel.
    • Use the pick to slice through the left edge of the phone.
    • If the screen feels hard to slice, heat the left edge for one minute and try again.
    • Leave the pick inserted along the left edge of the phone to prevent the adhesive from re-sealing.
  8. Google Pixel 4a Screen Replacement: stap 8, afbeelding 1 van 3 Google Pixel 4a Screen Replacement: stap 8, afbeelding 2 van 3 Google Pixel 4a Screen Replacement: stap 8, afbeelding 3 van 3
    • Insert another opening pick into the left edge of the phone at an angle where a gap has already formed to prevent damage to the OLED panel.
    • Slide the pick around the top edge of the phone to cut the adhesive.
    • If the screen feels hard to slice, heat the top edge for one minute and try again.
  9. Google Pixel 4a Screen Replacement: stap 9, afbeelding 1 van 2 Google Pixel 4a Screen Replacement: stap 9, afbeelding 2 van 2
    • Once you have cut around the perimeter of the phone, carefully lift the right edge of the screen, opening the phone like a book.
    • Do not remove the screen yet.
    • Use an opening pick to carefully cut through any remaining adhesive.
  10. Google Pixel 4a Screen Replacement, Flip the screen over: stap 10, afbeelding 1 van 3 Google Pixel 4a Screen Replacement, Flip the screen over: stap 10, afbeelding 2 van 3 Google Pixel 4a Screen Replacement, Flip the screen over: stap 10, afbeelding 3 van 3
    • Lift from the top edge and swing the screen over the bottom edge until you can rest it glass-side down.
    • Be careful not to put any stress on the attached ribbon cable.
  11. Google Pixel 4a Screen Replacement, Disconnect the display: stap 11, afbeelding 1 van 1
    • Use a pair of tweezers to carefully peel up the black tape covering the screen connector bracket.
    • If it is in good condition, you can re-use this tape during reassembly. Otherwise, replace it with a piece of electrical tape.
  12. Google Pixel 4a Screen Replacement: stap 12, afbeelding 1 van 1
    • Use a T3 Torx driver to remove the two 2.1 mm screws securing the screen connector bracket.
  13. Google Pixel 4a Screen Replacement: stap 13, afbeelding 1 van 1
    • Use a pair of tweezers to remove the screen connector bracket.
  14. Google Pixel 4a Screen Replacement: stap 14, afbeelding 1 van 2 Google Pixel 4a Screen Replacement: stap 14, afbeelding 2 van 2
    • Use the tip of a spudger to pry up and disconnect the screen flex cable.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  15. Google Pixel 4a Screen Replacement, Remove the screen: stap 15, afbeelding 1 van 1
    • Remove the screen.
    • Compare your replacement screen with the original. You may need to transfer additional components (such as speaker mesh) to the new part.
    • To install the new screen:
    • Scrape off remaining adhesive from the perimeter of the frame.
    • Follow this guide if you are using custom-cut adhesives.
    • If you are using double-sided tape such as Tesa tape, follow this guide.
Conclusie
71 andere personen hebben deze handleiding voltooid.
Sam Omiotek
72.622 Reputatie
288 handleidingen geschreven
31 opmerkingen
Really nice repair guide. But no place to buy the screen.
jeffreyjantos - Antwoord
Yep, still waiting for it to be available.
Paul -
Same, still waiting. I have a broken pixel 4a and I have a right to repair it.
Erik Fry -
Where do you recommend that I purchase the Pixel4a screen replacement from? I found these two with Witrigs being cheaper, but not sure if either are reliable high quality screens.
https://www.witrigs.com/oem-screen-repla...
https://phoneremedies.com/collections/go...
Alejandro Gaytan - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 65
Afgelopen 7 dagen: 557
Afgelopen 30 dagen: 2,331
Altijd: 174,425
