Inleiding
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Follow this guide to replace the charging port on a Google Pixel 4a.
The unreinforced display panel on the Pixel 4a is fragile. Pay special attention to the warnings in the opening procedure if you are reusing the screen.
Wat je nodig hebt
Insert a SIM eject tool, bit, or straightened paper clip into the SIM tray hole.
Press directly into the hole to eject the SIM card tray.
Remove the SIM card tray.
Take note of the two seams on the edge of the phone:
Screen seam: This seam separates the screen from the rest of the phone. This is where you should pry.
Frame seam: This is where the plastic frame meets the back cover. It is held in place by screws. Do not pry at this seam.
Before you begin, note the following areas on the screen:
Screen flex cable: Do not insert the opening pick deeper than instructed or you risk damaging this cable.
Adhesive perimeter: Prying beyond this narrow perimeter without angling the pick will damage the OLED panel.
Apply a heated iOpener to the right edge of the display for one minute to soften the adhesive.
Place a suction cup as close to the right edge of the screen as possible.
Lift the suction cup with a strong steady force.
Insert the tip of an opening pick into the screen seam no more than 1 mm.
With the pick 1 mm into the gap, pivot the pick upwards to a steep angle.
At a steep angle, carefully push the pick into the gap about 1/4 inch (6 mm). The pick should slide in below the OLED panel.
Slide the pick along the right edge of the screen to cut the adhesive.
Leave the pick in the top right corner to prevent the adhesive from re-sealing.
Insert another opening pick into the right edge of the phone at an angle where a gap has already formed to prevent damage to the OLED panel.
Slide the opening pick around the bottom of the phone to cut the adhesive.
Leave the pick inserted along the bottom edge to prevent the adhesive from resealing.
Insert another opening pick into the bottom edge of the phone at an angle where a gap has already formed to prevent damage to the OLED panel.
Use the pick to slice through the left edge of the phone.
Leave the pick inserted along the left edge of the phone to prevent the adhesive from re-sealing.
Lift from the top edge and swing the screen over the bottom edge until you can rest it glass-side down.
Use a pair of tweezers to carefully peel up the black tape covering the screen connector bracket.
Remove the screen.
Check if your replacement screen has speaker mesh and top edge adhesive pre-installed.
If it does, you won't need the top edge adhesive.
If it doesn't, remove the larger clear liner from the top edge adhesive and apply it to the screen (not the frame). Make sure the larger cutout lines up with the speaker mesh.
Follow this guide to apply the custom-cut adhesive.
Use a T3 Torx driver to remove the eight 4.3 mm screws securing the back cover to the midframe.
Insert an opening pick into the seam between the midframe and the back cover.
Slide the opening pick along the bottom edge of the phone to release the plastic clips securing the back cover to the midframe.
Use a T3 Torx driver to remove the seven screws securing the motherboard bracket:
Three 2.9 mm-long black screws
Three 2 mm-long screws
One 4.1 mm-long screw
Use the flat end of a spudger to pry up and disconnect the battery cable.
Use the tip of a spudger to disconnect the two flex cables connecting the fingerprint sensor and buttons to the motherboard.
Use the tip of a spudger to disconnect the headphone jack cable from the motherboard.
Pry up with the flat end of a spudger to disconnect the front-facing camera from the motherboard.
Use a T3 Torx driver to remove the two 4.1 mm screws securing the loudspeaker assembly.
Use the tip of a spudger to disconnect the loudspeaker cable from the motherboard.
Use a T3 Torx driver to remove the three screws securing the motherboard:
Two 2.9 mm-long black screws
One 2.1 mm-long screw
Use the corner of an opening pick to peel up the tape covering the earpiece speaker.
Insert the tip of a spudger underneath the bottom edge of the motherboard and pry it up enough to grip it with your fingers.
Use the flat edge of a spudger to disconnect the charging port from the motherboard.
Remove the charging port.
18 andere personen hebben deze handleiding voltooid.
11 opmerkingen
Thanks a lot Sam!
After making the repair, I was unable to connect to the cellular network or my home wireless. Any idea why that happened? I checked the blue and white wires and they are both connected. Any help would be appreciated. Oh, and my sim card is back in the phone :D.
I did a factory reset and now the wireless is working, but the sim card still isn't... I may have to try an esim card. Otherwise the repair went well.
I accidentally broke the orange screen cable in step 7, is there any way I could repair it myself, or should I just buy a replacement for it when they come back in stock?
charging port is now working, I can hear the phone start up but the screen is blank. Any suggestions?
