Inleiding
Does your Pixel have a broken or cracked screen? Follow this guide to replace it!
The Pixel 3a’s unreinforced display panel is fragile. If you are reusing the screen, be sure to pay special attention to the warnings in the opening procedure.
Wat je nodig hebt
Take note of the two seams on the phone:
Screen seam: This seam separates the screen from the rest of the phone. This is where you should pry.
Frame seam: This is where the plastic frame meets the back cover. It is held in place by screws. Do not pry at this seam.
Before you begin prying, note the following areas on the screen:
Screen flex cable: Do not pry deeper than instructed, or you risk damaging this cable.
Adhesive perimeter: Prying beyond the narrow perimeter without angling the pick will damage the LCD.
Slice through the left edge of the phone, making sure to properly angle the pick below the LCD panel and insert it in no more than 1/4" (6 mm).
To angle the pick below the LCD panel, insert the point of the pick no more than 1 mm in, angle the pick upwards, and then slowly push the pick in 1/4".
Remove the screen.
Carefully compare your replacement screen with your original part. You may need to transfer additional components (such as the speaker mesh) to the new part.
Follow this guide if you are using custom-cut adhesives.
If you are using double-sided tape such as Tesa tape, follow this guide.
If your Pixel won't turn on after replacing the screen, there is a chance that the phone has silently turned on when the battery is re-connected. Hold the power button for a few seconds until the phone vibrates off. Afterwards, re-connect the screen, and try again.
Repair didn’t go as planned? Check out our Google Pixel 3a Answers community for troubleshooting help.
76 andere personen hebben deze handleiding voltooid.
49 opmerkingen
Any word on the replacement screens?
We should have replacement screens in stock in the next month or two! Thanks for your patience.
I’ve cracked not only my LCD screen, but also the frame seam (shown with orange line in step 1 above). Will you be posting a guide to replace this also, or could you incorporate into this guide? Also interested if this will be available as a spare? Thanks.
Hi Mark,
I’m sorry to hear that! The frame seam is part of the plastic midframe—you would need to replace the midframe to replace the cracked seam. Instructions on how to do so can be found in this guide.
Because the Pixel 3a is a relatively new phone, replacement parts are harder to find for it. You can always buy a broken phone and transfer the part over, or use some adhesive to hold the cracked frame seam in place.
