Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray, located on the left edge of the phone, opposite of the power and volume buttons.
Press firmly to eject the tray.
Stap 3
Voorzichtig: stappen 3-14 komen van een handleiding die in bewerking is.
Apply a suction cup as close to the SIM slot edge of the phone as you can while avoiding the curved edge.
Pull up on the suction cup with firm, constant pressure and insert an opening pick between the front panel and rear case.
Do not insert the pick more than 0.25 inches (6 mm) into the bottom edge of the phone. If the pick contacts the folded portion of the OLED panel, it can damage the display.
Do not cut along the left edge; there are delicate display cables that can be damaged.
Only make very shallow cuts in the upper left corner; prying deeply can damage the front-facing camera.
Slide the opening pick down the right side of the phone to separate the display adhesive.
Slide the opening pick around the lower-right corner and along the bottom edge of the phone.
Reinsert the flat edge of the pick at the top-right corner of the phone, and slide it around the corner and the top edge of the phone.
Gently lift the display from the right side of the phone, opening it like a book.
Carefully lay the display flat on the table next to the rest of the phone, keeping it close to the phone to avoid straining the display and digitizer cables.
Use the corner of an opening tool to pry up and unclip on the lower edge of the digitizer cable connector cover.
Remove the connector cover.
Use the point of a spudger to lift the digitizer cable connector up and out of its socket on the motherboard.
Use tweezers to remove any tape from the display connector cover.
Insert the point of a spudger into the small hole on the edge of the display connector cover.
Use the spudger to pry the cover out of its recess.
Use the flat edge of a spudger to lift the display cable connector up from its socket.
Remove the display.
Gereedschap gebruikt in deze stap:Magnetic Project Mat$19.95-
Remove eleven 3.8 mm Phillips screws securing the midframe.
Insert an opening tool into the notch in the midframe near the volume buttons and pry the midframe up and away from the rest of the phone.
Remove the midframe.
Use the flat end of a spudger to disconnect the battery connector.
Use the point of a spudger to disconnect the front-facing camera connector.
Use the flat end of a spudger to disconnect the right Active Edge sensor connector.
Disconnect the antenna cable.
Use the point of a spudger to disconnect the fingerprint sensor connector.
Use the flat end of a spudger to disconnect the left Active Edge sensor connector.
Use the flat end of a spudger to disconnect the charging assembly connector.
Use the point of a spudger to disconnect the front-facing sensor assembly connector.
Make sure all the cables and connectors are clear of the board, and use the flat edge of a spudger to gently lift the bottom of the motherboard.
Holding the wide part of the motherboard near the SIM card slot, carefully slide the board toward the bottom of the phone while lifting it out of the phone.
Remove the motherboard.
Try to keep the phone flat with the battery facing up after you remove the motherboard, as the front-facing camera can fall out of the phone case very easily.
Slide the point of a spudger under the lower left side of the loudspeaker and slowly pry the speaker assembly up from the phone.
7 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Does this method work with the earpiece one as well?
We don’t have official instructions out for the earpiece speaker, but it’s only accessible underneath the glass panel and antenna assembly on the back of the phone so removing it is a bit different. After removing the motherboard you would have to lift this flex cable from the back of the phone, just enough to separate it from the adhesive holding it down. Then you can carefully pry up the glass panel, and remove antenna assembly and the earpiece speaker underneath. You’ll probably need an iOpener, suction cup, and opening picks to remove the panel and everything underneath—they’re all glued down pretty solidly.
