Inleiding
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Use this guide to replace the charging assembly in your Pixel 2 XL. The charging assembly contains the USB-C port, microphone, and other hardware.
Wat je nodig hebt
Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray, located on the left edge of the phone, opposite of the power and volume buttons.
Press firmly to eject the tray.
Stap 3 Opening Procedure
Voorzichtig: stappen 3-14 komen van een handleiding die in bewerking is.
Apply a suction cup as close to the SIM slot edge of the phone as you can while avoiding the curved edge.
Shouldn’t this be “As close as possible to the volume rocker”?
Forget about the tiny toy suction cup they provide to battery replacement kits. I used a dent puller from an automotive shop. The smallest they had was just small enough for the Pixel's screen. I still needed to heat the edges with a heat gun.
I wish someone tell me in advance that if I doing this replacement after using phone for a few years it better to have spare "display adhesive" and be ready to follow Google Pixel 2 XL Display Adhesive Replacement
Original adhesive become dirty with time and fat chances it will be damaged during opening phase. In my case I replaced battery but can't use the phone, as still waiting for adhesive to be delivered -
Pull up on the suction cup with firm, constant pressure and insert an opening pick between the front panel and rear case.
Whatever happened to “Do not heat your phone. If needed, you can use a dropper or syringe to inject isopropyl alcohol (90+%) around the edges of the back cover to weaken the adhesive.”?
It is in concern with swollen batteries.
I spent an hour trying to get the glass screen apart from the body. I tried the hairdryer etc but made no progress. However, when I used a sucker to gently pull on the glass it was easy.
I used a heat gun, and the metal spatula in the iFixit kit. I broke the screen. Then, continuing with a blue plastic triangle, the screen continued to break. It seems to be quite brittle.
Never use metal tools on glass component
p43j77 -
Just broke the screen as well. I’d say heat gun is a must, otherwise it’s really hard to slide pick at the top and bottom without breaking the screen. It’s a very thin line of glass over there.
I thought I did this perfectly. I used the iOpener to heat the glue, and the picks to slide around the screen to release the adhesive. I preformed the rest of the repair (charging assembly and the battery) with little issue. Just reassembled and the volume rocker side of the screen is white. I took less care on this side since the instructions said that you didn’t need to worry about how far the pick went in. NOT TRUE! There is a curvature to that edge that will push your pick up into the back of the unprotected display. It clearly doesn’t take much to damage it. I was so careful! F&CK!! I should have just created the e-waste and bought a new device. So mad!
Do not insert the pick more than 0.25 inches (6 mm) into the bottom edge of the phone. If the pick contacts the folded portion of the OLED panel, it can damage the display.
Do not cut along the left edge; there are delicate display cables that can be damaged.
Only make very shallow cuts in the upper left corner; prying deeply can damage the front-facing camera.
Use the corner of an opening tool to pry up and unclip on the lower edge of the digitizer cable connector cover.
Remove the connector cover.
Lol mine shot off and Ricocheted off the ceiling! Then landed on my shoulder haha
It literally popped me right in the middle of the forehead. My wife is still making fun of me.
Mine flew off while I was laughing you guys, never too be seen again: (
I decided to work outdoors, didn't read any comments first, so when mine flew off I found it five cursing minutes later in a crack on the driveway. Should have read the comments first! Thanks hamiltont. Will now read every comment BEFORE attempting step.
Confirmed, this $@$* can fly!
Use the point of a spudger to lift the digitizer cable connector up and out of its socket on the motherboard.
This small connector gave me fits getting it located correctly, is there a trick to getting it aligned since it’s difficult to see around edge of the connector?
Use the flat edge of a spudger to lift the display cable connector up from its socket.
Remove the display.
BE EXTRA CAREFUL HERE, and during reassembly! There are 2 itty bitty parts directly under this ribbon cable connector that, if damaged, will render your loudspeaker unusable. The only sure way to fix it if you break it is to replace the motherboard. There are some reports of people being able to solder the spots and shorting it to make it work, and that worked for me for a time, but they’re really tiny (about 0.5 mm) and if you don’t get a secure solder, or if you bleed over, it will also mess up your top speaker.
Saw this comment after I’ve done replacing and sure enough, the loud speaker was broken. The resistor was knocked over but still hanging in place so I just stuck it back and it works for now.
They are 2 black resistors at the end of the cable’s connector. So follow the above photo exactly and pry the connector from the side, not from the end of the connector like I did
What wasn't clear to me here (because I didn't put Step 13 together with Step 12, I suppose?) is that if your replacement part came with speaker grills and camera gasket, Step 12 is your final step. You are done, except for replacing the cables and covers, then placing the adhesive strips onto the replacement part and sticking the phone back together.
I ordered my screen from iFixit and it came with new grills and camera gasket already installed. I was able to use the thinnest strips on the supplied Tesa patch to line the entire screen perimeter piecemeal, then stick it back together like new.
Gereedschap gebruikt in deze stap:Magnetic Project Mat$19.95
Remove eleven 3.8 mm Phillips screws securing the midframe.
Insert an opening tool into the notch in the midframe near the volume buttons and pry the midframe up and away from the rest of the phone.
Remove the midframe.
How do I reattach the midframe? it seems like there are a lot of tabs that need to be reinserted carefully
Slide in the bottom part at an angle in first since it has some tabs. Otherwise it will get stuck halfway on top
Use the flat end of a spudger to disconnect the battery connector.
Use the point of a spudger to disconnect the front-facing camera connector.
Use the flat end of a spudger to disconnect the right Active Edge sensor connector.
Disconnect the antenna cable.
Also disconnect the antenna cable just to the right of the right Active Edge sensor connector
Make sure all the cables and connectors are clear of the board, and use the flat edge of a spudger to gently lift the bottom of the motherboard.
Holding the wide part of the motherboard near the SIM card slot, carefully slide the board toward the bottom of the phone while lifting it out of the phone.
Remove the motherboard.
Try to keep the phone flat with the battery facing up after you remove the motherboard, as the front-facing camera can fall out of the phone case very easily.
Agreed. No mention of the antenna cable.
Slide the point of a spudger under the lower left side of the loudspeaker and slowly pry the speaker assembly up from the phone.
This step was very difficult, I believe I just snapped the loudspeaker to the left of silver oval piece
I was just able to remove the loud speaker using the directions provided. The piece sprung out of the phone. The bottom of the piece is flat with pieces of metal and it appears to be slightly bent from my prying. We will see if it still works.
I ended up using my metal silver spudger. It goes in farther without prying on the fragile plastic. I’m replacing the charging circuit anyway, so not too worried about minor damage
This is a difficult step. Pictures indicating other safe pry points would be helpful.
Most stubborn component to remove.
I was able to remove this without great stress on the part by inserting my right thumbnail (thumbprint facing the battery / top of the phone) in between the loudspeaker and the phone body above the silver oval, while at the same time using my left index fingernail to gently lift the long left side protrusion of the loudspeaker. Note that the plastic opening picks were too thick for this. Took twenty minutes or more to figure this out, but about two minutes or less to do it. The fundamental problem seems to be that this part is friction-fit into place, and you won’t get it out all in one motion without risk of breaking it, you have to work at it alternately from every angle. I also added a few drops of everclear (95% ethanol, isopropyl was hard to come by because of COVID), which may or may not have mattered (I have no control for this experiment). I believe there was no damage to the part.
Use the point of a spudger to disconnect the white antenna cable to the right of the battery.
The antenna cable was difficult to re-connect due to a slight misalignment of the new charging assembly (which of course is held in place by adhesive and hard to re-position as a result).
Use a hairdryer or heat gun, or prepare an iOpener and apply it to the bottom of the back of the phone for about a minute, in order to soften the adhesive securing the charging assembly.
Starting from the left side, slide an opening pick under the charging assembly flex cable to separate it from the phone case.
Yes, there is a small plastic retainer. But I think I think it secures the microphone in place? I think that is the component to the left of the charging port? It’s connected to a channel that exits the body at the mesh screen…
The small plastic retainer was stuck. I did step 31 first, then I came back to this and used 3 drops of 95% ethanol to soften whatever was sticking before proceeding to step 30.
Lift the charging assembly out of the phone case.
When reversing this step to install a new charging assembly, consider how you will re-attach the antenna cable disconnected in step 27 — a slight misalignment made it very difficult to reconnect.
32 andere personen hebben deze handleiding voltooid.
12 opmerkingen
Why do I need the Tesa 61395 Tape for this repair? I don’t see it used anywhere in the guide.
Hey Jay,
The Tesa tape is needed only necessary if you do not use the custom-cut back display panel adhesive.
Should I apply some kind of glue around the port?
Is there any possibility to keep it waterproof?
Hi Erik,
Once you have opened the phone, there is no reliable DIY way to make it water resistant.
can I just send the phone to you for repair? I’ve worked on PC motherboards half my life but this work seems to tedious for me? Its a great demo tho!
While we fix many things at iFixit, we do not offer it as a service. Your best option would be to find a reputable local repair shop and have them fix your Pixel. Good luck!
should we apply glue to the new battery and charging port when we replace them? what kinds of glue?
So satisfying that my phone is back up and charging! Thank you!
The Pixel 2XL has been an excellent phone…not ready to give it up yet!
Is anyone here missing a capacitor on the charging port?
When I took the charging port out of the housing, I noticed a capacitor missing on it. Was wondering if it is important because I bought two new charging ports and one of them has the exact same capacitor missing.
It seems to be in charge of the microphone, but I’m not sure if its vital for it to function properly.
If anyone is missing this capacitor, or no what it does it will be much appreciated.
Thanks for your time
Imgur Link:
