Ga door naar hoofdinhoud
Google Home Motherboard Replacement
Wat je nodig hebt
  1. Google Home Motherboard Replacement, Interconnect Cable: stap 1, afbeelding 1 van 3 Google Home Motherboard Replacement, Interconnect Cable: stap 1, afbeelding 2 van 3 Google Home Motherboard Replacement, Interconnect Cable: stap 1, afbeelding 3 van 3
    • Removing the lid too quickly could cause you to tear the interconnect cable that attaches the base to the top of the lid.
    • Pull off the Google Home’s magnetically attached base and set it aside.
    • Using a Torx T6 screwdriver head, unscrew the four 1.7mm Torx screws deep in the speaker recess so that you can remove the lid.
    • After all four screws are out, pop the lid off the device to open the capsule.
    Vraag FixBot
  2. Google Home Motherboard Replacement: stap 2, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Carefully remove the interconnect cable using a pair of tweezers.
    Vraag FixBot
  3. Google Home Motherboard Replacement, Mute Button Switch: stap 3, afbeelding 1 van 2 Google Home Motherboard Replacement, Mute Button Switch: stap 3, afbeelding 2 van 2
    • Remove the ‘O-ring’ that wraps around the device holding the switch panel in place.
    Vraag FixBot
  4. Google Home Motherboard Replacement: stap 4, afbeelding 1 van 2 Google Home Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Using a Torx T6 screwdriver head, unscrew the four black 1.7mm Torx screws.
    • Remove the panel and the mute button switch. If done correctly you should now be able to see the device’s guitar-shaped motherboard.
    Vraag FixBot
  5. Google Home Motherboard Replacement, Motherboard: stap 5, afbeelding 1 van 2 Google Home Motherboard Replacement, Motherboard: stap 5, afbeelding 2 van 2
    • Disconnect the foam-padded, red and black cable that connects the motherboard to the sound driver, by squeezing and pulling on the tab
    • Disconnect the orange interconnect cable that connects the bottom of the device to the motherboard by pulling straight out on the orange tab.
    Vraag FixBot
  6. Google Home Motherboard Replacement: stap 6, afbeelding 1 van 2 Google Home Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Using a Torx T6 screwdriver head, unscrew the five silver 1.7mm Torx screws keeping the motherboard in place.
    • Remove the motherboard.
    Vraag FixBot
Conclusie
3 andere personen hebben deze handleiding voltooid.
Maya Wharton
193 Reputatie
1 Handleiding geschreven
Cal Poly, Team S24-G11, Maness Spring 2018 Lid van Cal Poly, Team S24-G11, Maness Spring 2018
CPSU-MANESS-S18S24G11
4 Leden
5 handleidingen geschreven
2Gids Commentaar
Where can one purchase a replacement motherboard?
Jim Pflasterer - Antwoord Deel
Most likely the only place to do so would be through contacting Google, as there is no parts sold at retail, only full units
Nick Bergstrom - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 66
Altijd: 3,856
