Ga door naar hoofdinhoud
Google Chromebook Pixel 2 Back Panel Replacement
Wat je nodig hebt
  1. Google Chromebook Pixel 2 Back Panel Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Flip your device over so the bottom panel is facing up.
  2. Google Chromebook Pixel 2 Back Panel Replacement: stap 2, afbeelding 1 van 1
    • Peel off the black rubber strips from top and bottom of the back panel.
  3. Google Chromebook Pixel 2 Back Panel Replacement: stap 3, afbeelding 1 van 2 Google Chromebook Pixel 2 Back Panel Replacement: stap 3, afbeelding 2 van 2
    • Remove the fifteen 3 mm Phillips #00 screws from the back panel.
  4. Google Chromebook Pixel 2 Back Panel Replacement: stap 4, afbeelding 1 van 1
    • Carefully lift the back panel off of the device.
Conclusie
Garrett Monteiro
413 Reputatie
3 handleidingen geschreven
Cal Poly, Team S22-G6, Livingston Spring 2017 Lid van Cal Poly, Team S22-G6, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G6
4 Leden
Één opmerking
Where can I buy replacements for the rubber strips? They never quite fit again and eventually were coming off and sticking to things, so had to throw them away.
Marc Bernard Schauber - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 19
Altijd: 1,416
