Ga door naar hoofdinhoud
GoPro Karma Arms Replacement
Wat je nodig hebt
  1. GoPro Karma Arms Replacement, Battery: stap 1, afbeelding 1 van 1
    • Hook your fingers on the tab and pull out the battery.
  2. GoPro Karma Arms Replacement, Stabilizer: stap 2, afbeelding 1 van 3 GoPro Karma Arms Replacement, Stabilizer: stap 2, afbeelding 2 van 3 GoPro Karma Arms Replacement, Stabilizer: stap 2, afbeelding 3 van 3
    • Locate stabilizer collar’s unlock and lock symbols. Twist the collar counterclockwise to unlock the stabilizer from GoPro Karma body.
    • Place the GoPro Karma on a stable surface with the legs folded in and the stabilizer facing towards yourself.
  3. GoPro Karma Arms Replacement: stap 3, afbeelding 1 van 1
    • Remove the stabilizer by pulling the entire stabilizer out of the drone body.
  4. GoPro Karma Arms Replacement, Landing Gear: stap 4, afbeelding 1 van 1
    • Flip the drone upside down with the landing gear out.
    • Remove the four 1.2 cm long hex screws with a Hex 2.0 screwdriver in the four corners of the landing gear
  5. GoPro Karma Arms Replacement: stap 5, afbeelding 1 van 1
    • Push with your thumb and pull up with your fingers to remove the landing gear.
    • Caution: The landing gear is connected by a thin cable so do not pull too far away.
  6. GoPro Karma Arms Replacement: stap 6, afbeelding 1 van 2 GoPro Karma Arms Replacement: stap 6, afbeelding 2 van 2
    • Flip over the landing gear and locate the cable connector.
    • Use your thumbnail to disconnect the cable and free the landing gear.
  7. GoPro Karma Arms Replacement, Arms: stap 7, afbeelding 1 van 1
    • Remove the two 1.2 cm long hex screws with a Hex 2.0 screwdriver and set them aside.
  8. GoPro Karma Arms Replacement: stap 8, afbeelding 1 van 2 GoPro Karma Arms Replacement: stap 8, afbeelding 2 van 2
    • Remove both locked connectors by pushing the connector release tool into the hole in the center and pulling up with the white handles.
    • The connector release tool is only included with the purchase of a replacement arm from the GoPro website.
    • If you do not have a connector release tool, use a small screwdriver to push each tab while pulling up with the white handles.
  9. GoPro Karma Arms Replacement: stap 9, afbeelding 1 van 3 GoPro Karma Arms Replacement: stap 9, afbeelding 2 van 3 GoPro Karma Arms Replacement: stap 9, afbeelding 3 van 3
    • Remove the cover plate by pulling up on the side.
    • Feed each connector through the hole and set aside the cover plate.
  10. GoPro Karma Arms Replacement: stap 10, afbeelding 1 van 2 GoPro Karma Arms Replacement: stap 10, afbeelding 2 van 2
    • Loosen the 2 cm long hex screw in the arm with a Hex 2.0 screwdriver.
    • The screw will not come out but loosen it until it can rotate easily.
    • Pull up and off the broken arm.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Kyle Hoff
141 Reputatie
1 Handleiding geschreven
Cal Poly, Team S25-G14, Maness Spring 2018 Lid van Cal Poly, Team S25-G14, Maness Spring 2018
CPSU-MANESS-S18S25G14
4 Leden
6 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 19
Altijd: 2,391
