Ga door naar hoofdinhoud
GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement
Wat je nodig hebt
  1. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement, Casing: stap 1, afbeelding 1 van 1
    • Power off your GoPro before beginning disassembly.
    • Unclip the black latch to the camera case and open the case.
  2. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: stap 2, afbeelding 1 van 1
    • Gently pry the back open by inserting a metal spudger between the case and back panel.
  3. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: stap 3, afbeelding 1 van 1
    • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
  4. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: stap 4, afbeelding 1 van 1
    • Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
  5. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: stap 5, afbeelding 1 van 1
    • Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
    • Make sure to keep track of these screws as they are very small.
  6. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: stap 6, afbeelding 1 van 1
    • Carefully remove the motherboard and white plastic piece from the case.
  7. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement, Micro USB/MicroSD Card Daughter Board: stap 7, afbeelding 1 van 2 GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement, Micro USB/MicroSD Card Daughter Board: stap 7, afbeelding 2 van 2
    • Remove the larger ribbon cable from the daughter board by lifting the black latch and pulling the ribbon cable gently from the socket.
    • Disconnect the smaller ribbon cable leading from the white plastic piece by simply pulling it from the socket.
  8. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: stap 8, afbeelding 1 van 1
    • Remove the two screws located on each side of the board with a Phillips screwdriver.
    • The screws go through an L metal bracket that will come off with the screws.
  9. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: stap 9, afbeelding 1 van 1
    • Separate the daughter board from the white plastic piece.
Conclusie
5 andere personen hebben deze handleiding voltooid.
River Drake
1.065 Reputatie
5 handleidingen geschreven
Cal Poly, Team 12-2, Lancaster Spring 2015 Lid van Cal Poly, Team 12-2, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G2
4 Leden
18 handleidingen geschreven
4Gids Commentaar
Wo kann ich ein daughterboard kaufen habt ihr da was für mich?
Lukas Blohm - Antwoord Deel
bravo! è scritto molto bene ed è stato utile. ma dove trovo il ricambio? non ci riesco!!!
michele - Antwoord Deel
Terrific guide. Does anyone know where to buy the “daughter board”?
fedebossert - Antwoord Deel
fedebossert - 05/27/20
<a href="https://www.w3schools.com/">Visit W3Schools.com!</a>
pavan kalyan - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 28
Afgelopen 30 dagen: 107
Altijd: 5,477
