Inleiding
If you are having trouble with your USB connection you might need to replace the USB port. This is a guide for replacing the USB connection port on the Hero4 Black.
Wat je nodig hebt
First, you will have to remove the faceplate by carefully using the spudger around the edge to loosen the clips.
After loosening the clips on the edge, pull the faceplate off.
8 andere personen hebben deze handleiding voltooid.
