Inleiding
Use this guide to replace the LCD housing on your GoPro Hero3 Silver.
Wat je nodig hebt
Use the plastic opening tool to remove the faceplate.
There is some adhesive and clips so be careful and the faceplate should pop right off.
Use the spudger to gently pry off the connector of the housing to the motherboard.
You should now have the motherboard assembly and the housing separated.
At this point you can easily change the LCD assembly by unplugging the ribbon and removing the existing screen. No need to proceed further if you're only replacing the screen.
5 andere personen hebben deze handleiding voltooid.
