Inleiding
No camcorder is complete without beeps to give you feedback to know that you're pressing the right buttons. If you launched your GoPro off a cliff and it no longer produces any sounds, you probably need a new speaker.
Wat je nodig hebt
Place your thumb on the indentation in the back case on the side of the GoPro.
Gently press down with your thumb and lift the back cover away from the case to remove it.
Slide a plastic opening tool between the battery and the rear case.
Gently pry the battery up and out of the rear case.
Remove the four Phillips #00 screws securing the rear case to the rest of the device:
Two 5.5 mm coarse thread screws.
Two 4.4 mm fine thread screws.
Remove the three screws securing the motherboard assembly to the front case:
Two 10.8 mm Phillips #00 screws.
One 4.8 mm Phillips #00 screw.
Use a soldering iron and solder wick to desolder the speaker contacts on the motherboard assembly.
For an in-depth tutorial on surface mount soldering and desoldering technique, see our Repairing Soldered Connections guide.
