Ga door naar hoofdinhoud
Glass Door Latch Replacement
Wat je nodig hebt
  1. Glass Door Latch Replacement, Outer Removal: stap 1, afbeelding 1 van 3 Glass Door Latch Replacement, Outer Removal: stap 1, afbeelding 2 van 3 Glass Door Latch Replacement, Outer Removal: stap 1, afbeelding 3 van 3
    • Using a Phillips #3 screwdriver, unscrew the two 50mm screws on the inner and outer handles.
    • Remove the handles.
  2. Glass Door Latch Replacement, Preparation: stap 2, afbeelding 1 van 3 Glass Door Latch Replacement, Preparation: stap 2, afbeelding 2 van 3 Glass Door Latch Replacement, Preparation: stap 2, afbeelding 3 van 3
    • Using the latch key, make sure the key is pointed in the downward position.
    • Insert the second screwdriver or dowel into the bottom hole or latch key hole to prevent the mechanism from falling.
    • The latch mechanism can fall down into the door if the screwdriver/dowel is not inserted.
  3. Glass Door Latch Replacement: stap 3, afbeelding 1 van 2 Glass Door Latch Replacement: stap 3, afbeelding 2 van 2
    • Using a Phillips #3 screwdriver, remove the two 13mm screws from the door while holding the latch.
    • Make sure to hold the latch while unscrewing the mechanism from the door.
  4. Glass Door Latch Replacement, Mechanism Removal: stap 4, afbeelding 1 van 2 Glass Door Latch Replacement, Mechanism Removal: stap 4, afbeelding 2 van 2
    • While holding the latch, move the mechanism downwards and remove it from the door.
  5. Glass Door Latch Replacement, Replacement Prep: stap 5, afbeelding 1 van 2 Glass Door Latch Replacement, Replacement Prep: stap 5, afbeelding 2 van 2
    • Using the latch key, put the latch in the lock position.
    • While the mechanism can be installed without the latch being out. Using the latch as a handle will help the installation.
  6. Glass Door Latch Replacement, Installation: stap 6, afbeelding 1 van 3 Glass Door Latch Replacement, Installation: stap 6, afbeelding 2 van 3 Glass Door Latch Replacement, Installation: stap 6, afbeelding 3 van 3
    • Insert the mechanism top first while holding the latch.
    • Do not let go of the latch until completing Step 7.
  7. Glass Door Latch Replacement, Installation Cont.: stap 7, afbeelding 1 van 3 Glass Door Latch Replacement, Installation Cont.: stap 7, afbeelding 2 van 3 Glass Door Latch Replacement, Installation Cont.: stap 7, afbeelding 3 van 3
    • Using a Phillips #3 screwdriver, screw in the two 13mm screws in the original holes.
    • Remove the screwdriver or dowel from the hole once the mechanism is screwed into the door.
  8. Glass Door Latch Replacement, Latch Correction: stap 8, afbeelding 1 van 2 Glass Door Latch Replacement, Latch Correction: stap 8, afbeelding 2 van 2
    • Insert the latch key back into the keyhole.
    • Move the latch key back into the unlocked position.
  9. Glass Door Latch Replacement, Handle Placement: stap 9, afbeelding 1 van 3 Glass Door Latch Replacement, Handle Placement: stap 9, afbeelding 2 van 3 Glass Door Latch Replacement, Handle Placement: stap 9, afbeelding 3 van 3
    • Place the handles back into place and screw in the two 50mm screws with a Phillips #3 screwdriver.
    • Make sure the outer and inner handles are aligned. Nothing's worse than a misaligned door handle!
Conclusie
CJ Cummings
169 Reputatie
1 Handleiding geschreven
UW Tacoma, Team S1-G32, Cardinal Spring 2020 Lid van UW Tacoma, Team S1-G32, Cardinal Spring 2020
UWT-CARDINAL-S20S1G32
1 Lid
1 handleiding geschreven
Één opmerking
Thank you for sharing this. Btw here is a detailed guide on how to mortise a door latch. In addition to enhancing your practical skills, learning how to mortise a door latch can help you avoid paying a high locksmith fee.
Revolar Revolar - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 15
Afgelopen 7 dagen: 54
Afgelopen 30 dagen: 302
Altijd: 4,624
