Inleiding
This is a guide for removing the back cover on the Gigabyte Aero 15x for upgrades or for maintenance.
To start shut down your computer
Wat je nodig hebt
Using a Torx T6, remove the 13 screws. Remember their exact spot because 3 of them have different lengths. (marked on picture 2)
There are 3 screws are hidden by a black stickers. Simply push down on the screwdriver to catch the indentation of the screw.
Using plastic tools, you can start unclipping the back from the body. Insert one opening tool and insert a second. Slide the tools around to pop off the bottom of the laptop.
Do not unclip the back face fully; only the front and the two sides. You can nevertheless detach the 4 corners.
Before removing the hood, remember that it is held by 2 aluminum rails at the back (hinge side).
Remove the cover starting at the front two corners. Lift up at those corners.
To reassemble, follow these steps in reverse order.
4 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
