Ga door naar hoofdinhoud
General Disassembly LG VX8560
Wat je nodig hebt
  1. General Disassembly LG VX8560, General Disassembly LG VX8560: stap 1, afbeelding 1 van 1
    • Flip phone over so its backside is facing up.
  2. General Disassembly LG VX8560: stap 2, afbeelding 1 van 1
    • Push from indentation and slide battery cover away from phone to remove battery cover.
  3. General Disassembly LG VX8560: stap 3, afbeelding 1 van 1
    • Take out the battery once cover is off by gently prying with your fingers.
  4. General Disassembly LG VX8560: stap 4, afbeelding 1 van 1
    • Using a philips screwdriver, unscrew all 4 screws along the edge of the phone
  5. General Disassembly LG VX8560: stap 5, afbeelding 1 van 2 General Disassembly LG VX8560: stap 5, afbeelding 2 van 2
    • Using your plastic pry tool, insert the tool between the phone’s keypad cover and back cover and gently pry apart.
  6. General Disassembly LG VX8560: stap 6, afbeelding 1 van 1
    • Once the covers have been separated the motherboard will be visible. Do not separate the two covers completely. The covers will be held together by a screw on the axis of the phone.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jack Foley
37 Reputatie
3 handleidingen geschreven
Cal Poly, Team 13-62, Johann Spring 2013 Lid van Cal Poly, Team 13-62, Johann Spring 2013
CPSU-JOHANN-S13S13G62
4 Leden
12 handleidingen geschreven
Één opmerking
Concerning a LG Chocolate 3 still activated and perfectly working but with a damaged frame. Can you take the activated internal parts out of a damaged frame phone and install in a like new condition identical phone frame ?
Zamora - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 421
