Ga door naar hoofdinhoud
Inleiding
The circuit board of the remote transmits the movement instructions to the car. If the remote isn't transmitting, the following steps will show you how to replace the circuit board.
Note: This guide will involve soldering. For information on how to solder, please visit iFixit's Soldering Skills page.
Onderdelen
Geen onderdelen opgegeven.
  1. Remove the 5mm Phillips #0 screw from the remote control. Using the tab, lift the battery cover from the remote control to expose the battery. Using the tab, lift the battery cover from the remote control to expose the battery.
    • Remove the 5mm Phillips #0 screw from the remote control.
    • Using the tab, lift the battery cover from the remote control to expose the battery.
  2. Unscrew the six 5mm Phillips #0 screws on the back of the remote Separate the back of the remote from the front panel.
    • Unscrew the six 5mm Phillips #0 screws on the back of the remote
    • Separate the back of the remote from the front panel.
    • During re-assembly, make sure the plastic button covers on the front panel align with the buttons on the back panel. If they do not, the buttons may be forced into an always "pressed" state.
  3. PC Laptop batterijen
    An easy fix for a big power boost.
    Nu winkelen
    Nu winkelen
  4. Remove the two left and right buttons from their insets in the controller.
    • Remove the two left and right buttons from their insets in the controller.
  5. Remove the 5mm Phillips #0 screw that connects the antennae to the circuit board.
    • Remove the 5mm Phillips #0 screw that connects the antennae to the circuit board.
  6. Unscrew 5mm Phillips #0 screw located at the bottom of the board in the center.
    • Unscrew 5mm Phillips #0 screw located at the bottom of the board in the center.
    • Remove the circuit board from the casing.
  7. Make note of where each wire connects to the circuit board for re-assembly as they will be removed in the next step.
    • Make note of where each wire connects to the circuit board for re-assembly as they will be removed in the next step.
    • Using the copper solder wick, remove the solder connecting the nine wires to the circuit board.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Jake Stone
548 Reputatie
4 handleidingen geschreven
Cal Poly, Team 8-38, Amido Winter 2015 Lid van Cal Poly, Team 8-38, Amido Winter 2015
CPSU-AMIDO-W15S8G38
4 Leden
8 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 3
Afgelopen 7 Dagen: 31
Afgelopen 30 Dagen: 96
Altijd: 2,997
