Ga door naar hoofdinhoud
Gateway W350I Keyboard Replacement
Wat je nodig hebt
    1. Gateway W350I Keyboard Replacement, Battery Access: stap 1, afbeelding 1 van 1
      • Turn the laptop upside down and position it as shown in the image.
      Vraag FixBot
      Voeg opmerking toe
    2. Gateway W350I Keyboard Replacement, Unlocking the Battery: stap 2, afbeelding 1 van 3 Gateway W350I Keyboard Replacement, Unlocking the Battery: stap 2, afbeelding 2 van 3 Gateway W350I Keyboard Replacement, Unlocking the Battery: stap 2, afbeelding 3 van 3
      • Slide the locking switch towards the open lock picture.
      • Hold the release switch in the unlocked position while simultaneously pushing the battery away from the laptop.
      • Once the laptop is disengaged, completely remove the battery from the laptop.
      Vraag FixBot
      Voeg opmerking toe
    1. Gateway W350I Keyboard Replacement, Unscrewing the Speaker Cover Panel: stap 3, afbeelding 1 van 1
      • Remove a 4mm Phillips #0 screw just beneath the battery that holds the speaker cover panel.
      Vraag FixBot
      Voeg opmerking toe
    2. Gateway W350I Keyboard Replacement, Unscrewing the Keyboard: stap 4, afbeelding 1 van 2 Gateway W350I Keyboard Replacement, Unscrewing the Keyboard: stap 4, afbeelding 2 van 2
      • Remove the 4mm Phillips #0 screw that secures the keyboard.
      Vraag FixBot
      Voeg opmerking toe
    3. Gateway W350I Keyboard Replacement, Repositioning the Device: stap 5, afbeelding 1 van 1
      • Reposition the laptop so that it is upright with the display open.
      Vraag FixBot
      Voeg opmerking toe
    4. Gateway W350I Keyboard Replacement, Removing the Speaker Cover Panel: stap 6, afbeelding 1 van 3 Gateway W350I Keyboard Replacement, Removing the Speaker Cover Panel: stap 6, afbeelding 2 van 3 Gateway W350I Keyboard Replacement, Removing the Speaker Cover Panel: stap 6, afbeelding 3 van 3
      • Carefully pry up on the right and left sides of the speaker cover panel.
      • The panel has a cable that connects it to the laptop, so do not pull the panel completely away from the laptop. Instead, disconnect the panel and move it slightly so that it does not interfere with the keyboard.
      Vraag FixBot
      Voeg opmerking toe
    5. Gateway W350I Keyboard Replacement, Removing the Keyboard: stap 7, afbeelding 1 van 2 Gateway W350I Keyboard Replacement, Removing the Keyboard: stap 7, afbeelding 2 van 2
      • Gently pry up on the corners of the keyboard with the plastic opening tool to free the keyboard.
      Vraag FixBot
      Voeg opmerking toe
    6. Gateway W350I Keyboard Replacement, Disconnecting the Keyboard: stap 8, afbeelding 1 van 2 Gateway W350I Keyboard Replacement, Disconnecting the Keyboard: stap 8, afbeelding 2 van 2
      • Pull on the cord connecting the keyboard to the computer until it slides out.
      • Be careful while removing the cord as it is very delicate.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Spencer
278 Reputatie
2 handleidingen geschreven
USF Tampa, Team 4-1, Brown Fall 2014 Lid van USF Tampa, Team 4-1, Brown Fall 2014
USFT-BROWN-F14S4G1
3 Leden
30 handleidingen geschreven
1Gids Commentaar
Great guide guys!
stewilli - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 44
Altijd: 1,908
