Ga door naar hoofdinhoud
Gateway W350I Display Replacement
Wat je nodig hebt
  1. Gateway W350I Display Replacement, Battery Access: stap 1, afbeelding 1 van 1
    • Turn the laptop upside down and position it as shown in the image.
  2. Gateway W350I Display Replacement, Unlocking the Battery: stap 2, afbeelding 1 van 3 Gateway W350I Display Replacement, Unlocking the Battery: stap 2, afbeelding 2 van 3 Gateway W350I Display Replacement, Unlocking the Battery: stap 2, afbeelding 3 van 3
    • Slide the locking switch towards the open lock picture.
    • Hold the release switch in the unlocked position while simultaneously pushing the battery away from the laptop.
    • Once the laptop is disengaged, completely remove the battery from the laptop.
  3. Gateway W350I Display Replacement, Remove Rubber Protectors & Screws: stap 3, afbeelding 1 van 2 Gateway W350I Display Replacement, Remove Rubber Protectors & Screws: stap 3, afbeelding 2 van 2
    • Pry the six black rubber protectors out of the screw holes.
    • Remove all six of the 4mm Phillips #0 screws that were covered by the rubber protectors.
  4. Gateway W350I Display Replacement, Separate Plastic Casing: stap 4, afbeelding 1 van 2 Gateway W350I Display Replacement, Separate Plastic Casing: stap 4, afbeelding 2 van 2
    • Separate the plastic screen casing from the laptop lid by inserting a plastic opening tool. Complete this step around the top and along both sides of the screen.
  5. Gateway W350I Display Replacement, Remove Bracket from Laptop Lid: stap 5, afbeelding 1 van 2 Gateway W350I Display Replacement, Remove Bracket from Laptop Lid: stap 5, afbeelding 2 van 2
    • Remove the two 4mm Phillips #0 screws located at the top that fasten the screen bracket to the laptop.
  6. Gateway W350I Display Replacement, Remove LCD Screen from Bracket: stap 6, afbeelding 1 van 1
    • Separate the bracket and the screen from its original position within the lid of the laptop.
    • Remove the four 4mm Phillips #0 screws on the sides of the bracket that hold the LCD screen.
  7. Gateway W350I Display Replacement, Remove Video Cable: stap 7, afbeelding 1 van 2 Gateway W350I Display Replacement, Remove Video Cable: stap 7, afbeelding 2 van 2
    • Detach the video cable that is attached to the laptop from the back of the screen.
    • Be careful while removing the video cable as it is very delicate.
  8. Gateway W350I Display Replacement: stap 8, afbeelding 1 van 2 Gateway W350I Display Replacement: stap 8, afbeelding 2 van 2
    • Disconnect the camera connector from the circuit board to completely free the screen.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Samuel Newton
296 Reputatie
1 Handleiding geschreven
USF Tampa, Team 4-1, Brown Fall 2014 Lid van USF Tampa, Team 4-1, Brown Fall 2014
USFT-BROWN-F14S4G1
3 Leden
10 handleidingen geschreven
Één opmerking
It was very easy to follow.
Very friendly guide.
Stephan Williams - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 18
Altijd: 1,261
