Inleiding
This repair will be needed in circumstances where the screen on your laptop stops working properly. If software adjustments do not fix the issue, replacing the display with a new screen should correct the display issue.
Wat je nodig hebt
Slide the locking switch towards the open lock picture.
Hold the release switch in the unlocked position while simultaneously pushing the battery away from the laptop.
Once the laptop is disengaged, completely remove the battery from the laptop.
Pry the six black rubber protectors out of the screw holes.
Remove all six of the 4mm Phillips #0 screws that were covered by the rubber protectors.
Separate the plastic screen casing from the laptop lid by inserting a plastic opening tool. Complete this step around the top and along both sides of the screen.
Remove the two 4mm Phillips #0 screws located at the top that fasten the screen bracket to the laptop.
Separate the bracket and the screen from its original position within the lid of the laptop.
Remove the four 4mm Phillips #0 screws on the sides of the bracket that hold the LCD screen.
Detach the video cable that is attached to the laptop from the back of the screen.
3 andere personen hebben deze handleiding voltooid.
