Ga door naar hoofdinhoud
Gateway Solo 1450 Battery Replacement
  1. Gateway Solo 1450 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure the device is powered down and disconnected from any power sources. Doing this will eliminate any electrical hazards while working on the device.
    • First it is necessary to locate the battery release button. With the laptop orientated so that the screen hinges are facing up the button is located about halfway up the laptop and slightly to the left.
  2. Gateway Solo 1450 Battery Replacement: stap 2, afbeelding 1 van 2 Gateway Solo 1450 Battery Replacement: stap 2, afbeelding 2 van 2
    • The next step is to simultaneously push up on the battery release button and to pull out on the battery itself. If this is not done simultaneously then the battery will not budge.
  3. Gateway Solo 1450 Battery Replacement: stap 3, afbeelding 1 van 1
    • To fully free the battery it is necessary to firmly grasp the battery and give it a firm tug.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Timothy Post
112 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team S5-G4, Peak Spring 2018 Lid van UMass Dartmouth, Team S5-G4, Peak Spring 2018
UMASSD-PEAK-S18S5G4
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 14
Altijd: 300
