Inleiding
To replace a faulty keyboard and damaged frame follow this replacement guide.
A functioning keyboard is imperative to any laptop. The keyboard frame, by extension, ensures that the keyboard and trackpad remain safe. If your keys are sticking or if you notice a lag on your mouse, this could be due to debris under the keyboard panel and frame.
Wat je nodig hebt
Locate the battery latch on the bottom of the laptop.
Release the latch by pressing it with your thumb and sliding it to the right.
Slide the battery out of its compartment.
Turn the device so the back is facing you.
Unscrew the 2 mm screws with a Phillips #0 screwdriver.
