Ga door naar hoofdinhoud
Gateway SA1 Screen Replacement
Wat je nodig hebt
  1. Gateway SA1 Screen Replacement, Battery: stap 1, afbeelding 1 van 1
    • Move the latch to the right of the battery to unlock.
  2. Gateway SA1 Screen Replacement: stap 2, afbeelding 1 van 1
    • Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
    • The latch must be held in position to remove the battery.
  3. Gateway SA1 Screen Replacement, Screen: stap 3, afbeelding 1 van 2 Gateway SA1 Screen Replacement, Screen: stap 3, afbeelding 2 van 2
    • Remove the hinge covers by lifting each with the sharp point of the spudger.
    • Notice that the middle cover has a different shape and is more difficult to remove.
  4. Gateway SA1 Screen Replacement: stap 4, afbeelding 1 van 2 Gateway SA1 Screen Replacement: stap 4, afbeelding 2 van 2
    • Remove the six screw covers on the front bezel with the sharp point of the spudger.
    • The bottom two are more difficult to remove.
  5. Gateway SA1 Screen Replacement: stap 5, afbeelding 1 van 1
    • Remove the six 5.9 mm Philips screws securing the screen bezel.
  6. Gateway SA1 Screen Replacement: stap 6, afbeelding 1 van 3 Gateway SA1 Screen Replacement: stap 6, afbeelding 2 van 3 Gateway SA1 Screen Replacement: stap 6, afbeelding 3 van 3
    • Remove the front bezel by prying it off with the wedged end of the spudger.
    • Verify that your spudger does not touch the LCD.
    • The screen inverter is now exposed below the LCD.
  7. Gateway SA1 Screen Replacement: stap 7, afbeelding 1 van 1
    • Remove the single 3.8mm Phillips screw mounting the screen inverter to the computer.
  8. Gateway SA1 Screen Replacement: stap 8, afbeelding 1 van 2 Gateway SA1 Screen Replacement: stap 8, afbeelding 2 van 2
    • Use your finger, or the spudger, to pry the inverter board out.
    • This exposes the wires behind it.
  9. Gateway SA1 Screen Replacement: stap 9, afbeelding 1 van 1
    • Unplug the LCD back light cables from the right side of the screen inverter.
  10. Gateway SA1 Screen Replacement: stap 10, afbeelding 1 van 2 Gateway SA1 Screen Replacement: stap 10, afbeelding 2 van 2
    • Remove the six screws that mount the screen to the hinge mounts.
    • Two 2.5 mm Phillips screws.
    • Four 3.8 mm Phillips screws.
  11. Gateway SA1 Screen Replacement: stap 11, afbeelding 1 van 1
    • Unplug the cable from the webcam board.
    • Be gentle, do not use excessive force or you may break the connection.
  12. Gateway SA1 Screen Replacement: stap 12, afbeelding 1 van 1
    • Separate the screen from the display cover.
    • Do not touch the back of the screen.
  13. Gateway SA1 Screen Replacement: stap 13, afbeelding 1 van 2 Gateway SA1 Screen Replacement: stap 13, afbeelding 2 van 2
    • Remove the three tape strips that hold down the cables.
    • Be careful not to tear any of the tape. The piece holding down the webcam wires is especially delicate.
  14. Gateway SA1 Screen Replacement: stap 14, afbeelding 1 van 2 Gateway SA1 Screen Replacement: stap 14, afbeelding 2 van 2
    • Unplug the display data cable from the screen connector.
    • This connection is very fragile; do not use excessive force.
    • The screen should now be free from all wire connections.
  15. Gateway SA1 Screen Replacement: stap 15, afbeelding 1 van 1
    • Remove the four 2.8 mm Phillips screws that secure the screen to the mounting bracket using a screwdriver.
    • There will be two screws on either side of the mounting bracket.
  16. Gateway SA1 Screen Replacement: stap 16, afbeelding 1 van 1
    • You can now remove and replace the screen.
Conclusie
Diego Carteno
258 Reputatie
7 handleidingen geschreven
Cal Poly, Team 24-20, Regan Spring 2010 Lid van Cal Poly, Team 24-20, Regan Spring 2010
CPSU-REGAN-S10S24G20
4 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 23
Altijd: 18,895
