Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Move the latch to the right of the battery to unlock.
Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
The disk drive should easily detach and can now be replaced.
Remove the twelve 5.9 mm Philips screws from the back cover.
Remove one 8.8 mm Philips screw from the back cover.
Unscrew the two 5.9 mm Philips screws located on the the side closest to the battery.
Unscrew the three 3.6 mm Philips screws that are within the Disk drive port.
Remove the hinge covers by lifting each with the sharp point of the spudger.
Unscrew the two 3.9 mm Philips screws and remove the keyboard.
Using the spudger, detach the connector by pushing two tabs away from the white connector and then gently pulling the connector away.
Lift up the black tab and gently pull out the connector.
Unscrew the five marked 3.8 mm Philips screws.
Three screws are located on the right side of the screen.
Two screws are located on the left side of the screen.
Remove the screen brackets from the computer's base.
Remove the four 5.9 mm Philips screws as indicated:
There is one somewhat hidden screw on the left side under the screen hinge, and one to the right of the (left)speaker, right/top side of the video port on mobo.
There are two similarly positioned screws on the right side.
The following steps (18 - 20) explain how to remove the three indicated connections.
The order is Blue, Violet, Orange.
Lift the white tab up and gently take out the connector.
Lift and pull the black tab upward until it becomes unattached.
Use the spudger to remove the casing as seen in the picture.
6 andere personen hebben deze handleiding voltooid.
