Ga door naar hoofdinhoud
Gateway SA1 Hard Drive Replacement
Wat je nodig hebt
  1. Gateway SA1 Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Move the latch to the right of the battery to unlock.
  2. Gateway SA1 Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
    • The latch must be held in position to remove the battery.
  3. Gateway SA1 Hard Drive Replacement, Hard Drive: stap 3, afbeelding 1 van 1
    • Before you begin, it's recommended that you back up all your computer's information on the original hard drive. Also, verify the laptop is off and all cables are disconnected.
    • Turn the laptop over so the bottom is facing up.
  4. Gateway SA1 Hard Drive Replacement: stap 4, afbeelding 1 van 2 Gateway SA1 Hard Drive Replacement: stap 4, afbeelding 2 van 2
    • Loosen the three Philips cover screws that secure the hard drive.
    • These screws cannot be fully removed from the hard drive cover.
    • Use the spudger to lift and to remove the hard drive cover.
  5. Gateway SA1 Hard Drive Replacement: stap 5, afbeelding 1 van 2 Gateway SA1 Hard Drive Replacement: stap 5, afbeelding 2 van 2
    • Slide the original hard drive to the left and lift it to remove.
    • Insert the new hard drive.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Diego Carteno
258 Reputatie
7 handleidingen geschreven
Cal Poly, Team 24-20, Regan Spring 2010 Lid van Cal Poly, Team 24-20, Regan Spring 2010
CPSU-REGAN-S10S24G20
4 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 34
Altijd: 13,914
