Ga door naar hoofdinhoud
Gateway NV59C66u Battery Replacement
  1. Gateway NV59C66u Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • First turn off your laptop, close it, then turn your laptop over exposing the bottom side.
    • Locate the Latches below the battery.
  2. Gateway NV59C66u Battery Replacement: stap 2, afbeelding 1 van 1
    • Slide the vertical latch upward, unlocking the battery
  3. Gateway NV59C66u Battery Replacement: stap 3, afbeelding 1 van 1
    • Slide the horizontal latch to the right so you are able to remove the battery from the bottom of your laptop.
  4. Gateway NV59C66u Battery Replacement: stap 4, afbeelding 1 van 1
    • Now the battery is free. Proceed to lift and remove the battery.
    • Place the old batter to the side, as to not get it confused from your new battery you intend to install.
    • Take your new battery and position it into the battery slot you took the old one out of.
    • Make sure latches are in the unlocked position and apply light pressure on the new battery to make sure it is in place.
    • Put latches in lock position and turn laptop over.
    • Turn on your computer.
Conclusie
Jackson Gandee
521 Reputatie
4 handleidingen geschreven
ETECH Holdings Lid van ETECH Holdings
Community
2 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 10
Altijd: 198
