Ga door naar hoofdinhoud
Inleiding
Be sure to unplug and power off the device before removing any components. Also, save any work before disassembly.
Onderdelen
Geen onderdelen opgegeven.
  1. Push orange locking tab with spudger right,  until battery lifts out of place. Laptop should be unplugged from power supply before removal. Laptop should be unplugged from power supply before removal.
    • Push orange locking tab with spudger right, until battery lifts out of place.
    • Laptop should be unplugged from power supply before removal.
  2. Unscrew the two  7 mm long #0 Phillips screws.
    • Unscrew the two 7 mm long #0 Phillips screws.
  3. Lift and remove the cover panel via the indentation in the middle of the panel.
    • Lift and remove the cover panel via the indentation in the middle of the panel.
  4. Push each of the two silver clips outward to release RAM board.
    • Push each of the two silver clips outward to release RAM board.
  5. Lift RAM board out of its compartment.
    • Lift RAM board out of its compartment.
Conclusie
Aaron Allison
433 Reputatie
5 handleidingen geschreven
IUPUI, Team S1-G1, Baechle Fall 2018 Lid van IUPUI, Team S1-G1, Baechle Fall 2018
IUPUI-BAECHLE-F18S1G1
3 Leden
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 3
Altijd: 53
