Inleiding
Both the battery and rear cover guides should be completed before completing this guide. This guide can be used for replacing a dying hard drive or upgrading your current hard drive.
Onderdelen
Geen onderdelen opgegeven.
  1. Push orange locking tab with spudger right,  until battery lifts out of place. Laptop should be unplugged from power supply before removal. Laptop should be unplugged from power supply before removal.
    • Push orange locking tab with spudger right, until battery lifts out of place.
    • Laptop should be unplugged from power supply before removal.
  2. Unscrew the two  7 mm long #0 Phillips screws.
    • Unscrew the two 7 mm long #0 Phillips screws.
  3. MacBook-reparatiesets voor batterijen
    Vanaf $69.99
    Buy Now
    Vanaf $69.99
    Buy Now
  4. Lift and remove the cover panel via the indentation in the middle of the panel.
    • Lift and remove the cover panel via the indentation in the middle of the panel.
  5. Push spudger to the left until hard drive is moved from its original position.
    • Push spudger to the left until hard drive is moved from its original position.
  6. Pull plastic flap and pull hard drive away from laptop.
    • Pull plastic flap and pull hard drive away from laptop.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Aaron Allison
433 Reputatie
5 handleidingen geschreven
IUPUI, Team S1-G1, Baechle Fall 2018 Lid van IUPUI, Team S1-G1, Baechle Fall 2018
IUPUI-BAECHLE-F18S1G1
3 Leden
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 1
Afgelopen 7 Dagen: 1
Afgelopen 30 Dagen: 3
Altijd: 81
