Ga door naar hoofdinhoud
Gateway NV53A24u Fan Replacement
Wat je nodig hebt
  1. Gateway NV53A24u Fan Replacement, Fan: stap 1, afbeelding 1 van 2 Gateway NV53A24u Fan Replacement, Fan: stap 1, afbeelding 2 van 2
    • Locate the top of the keyboard, then insert a spudger into the top most edge of the keyboard where it meets the bezel surrounding it.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but a regular black nylon spudger should be used whenever possible.
  2. Gateway NV53A24u Fan Replacement: stap 2, afbeelding 1 van 1
    • Using the spudger, lift the keyboard from its base to expose the underside components.
  3. Gateway NV53A24u Fan Replacement: stap 3, afbeelding 1 van 2 Gateway NV53A24u Fan Replacement: stap 3, afbeelding 2 van 2
    • Using a #4 phillips screwdriver, remove all six 2.3mm screws from the plastic shroud.
    • Then, lift off the shroud to reveal the motherboard beneath.
  4. Gateway NV53A24u Fan Replacement: stap 4, afbeelding 1 van 2 Gateway NV53A24u Fan Replacement: stap 4, afbeelding 2 van 2
    • The motherboard is now readily accessible to be removed.
    • Using a spudger, gently pry the ports away from their side port containers to easily remove it.
  5. Gateway NV53A24u Fan Replacement: stap 5, afbeelding 1 van 2 Gateway NV53A24u Fan Replacement: stap 5, afbeelding 2 van 2
    • Lift the motherboard up and flip it on its back.
    • With the motherboard flipped, the fan is almost ready to be removed.
  6. Gateway NV53A24u Fan Replacement: stap 6, afbeelding 1 van 2 Gateway NV53A24u Fan Replacement: stap 6, afbeelding 2 van 2
    • Locate the fan and its copper heat pipe running just behind it.
    • Remove the fan from the heat pipe using slight force as it is held to the pipe with an adhesive tape.
Conclusie
Minh Harper
156 Reputatie
1 Handleiding geschreven
USF Tampa, Team 1-5, Leahy Fall 2016 Lid van USF Tampa, Team 1-5, Leahy Fall 2016
USFT-LEAHY-F16S1G5
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 580
