Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the five identical 3/16" Phillips screws that secures the hard drive and memory cover using a Phillips #0 Screwdriver.
Lift up the base cover from the the top with your hands to a 90 degree angle.
Remove the base cover and place it in a safe and dry place.
Remove the 1/4" Phillip screw located at the top right of the Hard Drive using a Phillips #0 Screwdriver .
Remove the Hard Drive component from its compartment. To do so, slide the component downward away from the battery pack.
Lift the Hard Drive to a 90 degree angle and out of its slot.
Place the Hard Drive in a designated zone.
Remove the four identical 1/8" Phillip screws located in every corner of the Hard Drive using the Phillips #0 Screwdriver.
Access to the Hard drive by gently sliding the metal cover away from the Hard Drive.
