Ga door naar hoofdinhoud
Gateway NV52 Hard Drive Compartment Replacement
Wat je nodig hebt
  1. Gateway NV52 Hard Drive Compartment Replacement, Base Cover: stap 1, afbeelding 1 van 1
    • Remove the five identical 3/16" Phillips screws that secures the hard drive and memory cover using a Phillips #0 Screwdriver.
  2. Gateway NV52 Hard Drive Compartment Replacement: stap 2, afbeelding 1 van 1
    • Lift up the base cover from the the top with your hands to a 90 degree angle.
    • Remove the base cover and place it in a safe and dry place.
  3. Gateway NV52 Hard Drive Compartment Replacement, Hard Drive Compartment: stap 3, afbeelding 1 van 1
    • Remove the 1/4" Phillip screw located at the top right of the Hard Drive using a Phillips #0 Screwdriver .
  4. Gateway NV52 Hard Drive Compartment Replacement: stap 4, afbeelding 1 van 3 Gateway NV52 Hard Drive Compartment Replacement: stap 4, afbeelding 2 van 3 Gateway NV52 Hard Drive Compartment Replacement: stap 4, afbeelding 3 van 3
    • Remove the Hard Drive component from its compartment. To do so, slide the component downward away from the battery pack.
    • Lift the Hard Drive to a 90 degree angle and out of its slot.
    • Place the Hard Drive in a designated zone.
Conclusie
Tim En
557 Reputatie
4 handleidingen geschreven
Cal Poly, Team 7-24, Regan Spring 2014 Lid van Cal Poly, Team 7-24, Regan Spring 2014
CPSU-REGAN-S14S7G24
4 Leden
18 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 8
Altijd: 971
