Ga door naar hoofdinhoud
Gateway MS2370 RAM Replacement
Wat je nodig hebt
  1. Gateway MS2370 RAM Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure the laptop is turned off and flipped over so that the bottom is facing up. Then, locate the battery clip as shown.
  2. Gateway MS2370 RAM Replacement: stap 2, afbeelding 1 van 1
    • Either using your fingers or a plastic spudger push the battery clip to the left to release battery.
  3. Gateway MS2370 RAM Replacement: stap 3, afbeelding 1 van 1
    • Pull the battery from the laptop to remove it.
  4. Gateway MS2370 RAM Replacement, RAM: stap 4, afbeelding 1 van 1
    • Unscrew the three 10mm inch Phillips 01 screws on the back of your laptop.
    • Unplug everything from the USB and SD ports.
  5. Gateway MS2370 RAM Replacement: stap 5, afbeelding 1 van 1
    • Remove the cover panel.
    • This exposes more screws that must be removed.
  6. Gateway MS2370 RAM Replacement: stap 6, afbeelding 1 van 1
    • Unplug the two exposed cables from the motherboard.
  7. Gateway MS2370 RAM Replacement: stap 7, afbeelding 1 van 2 Gateway MS2370 RAM Replacement: stap 7, afbeelding 2 van 2
    • Unscrew the rest of the case screws which include several 10mm 01 Phillips screws and three 3mm 00 Phillips screws.
    • This marked screw will not fully come out. Just loosen it and leave it there it will not effect the rest of the replacement.
  8. Gateway MS2370 RAM Replacement: stap 8, afbeelding 1 van 2 Gateway MS2370 RAM Replacement: stap 8, afbeelding 2 van 2
    • Pry the laptop case apart.
    • The disc drive in this photo was removed. You can remove it just by puling it out when the previous step is completed.
  9. Gateway MS2370 RAM Replacement: stap 9, afbeelding 1 van 1
    • Unplug the track-pad and the keyboard ribbon cable by lifting up the grey flap and removing the cable.
    • This cable has a special connector the requires you to lift open a grey flap to unplug properly.
    • The keyboard plug is located at the center of the motherboard and can be unplugged like a normal cable.
  10. Gateway MS2370 RAM Replacement: stap 10, afbeelding 1 van 1
    • Remove the top half of the case.
  11. Gateway MS2370 RAM Replacement: stap 11, afbeelding 1 van 1
    • Unscrew all 5 10mm inch Phillips 01 screws.
    • One more off screen
  12. Gateway MS2370 RAM Replacement: stap 12, afbeelding 1 van 3 Gateway MS2370 RAM Replacement: stap 12, afbeelding 2 van 3 Gateway MS2370 RAM Replacement: stap 12, afbeelding 3 van 3
    • Unplug the ribbon cable connected to the USB Hub, the network card, and the monitor cable.
  13. Gateway MS2370 RAM Replacement: stap 13, afbeelding 1 van 1
    • Flip the motherboard over.
  14. Gateway MS2370 RAM Replacement: stap 14, afbeelding 1 van 3 Gateway MS2370 RAM Replacement: stap 14, afbeelding 2 van 3 Gateway MS2370 RAM Replacement: stap 14, afbeelding 3 van 3
    • Using your two thumbs to pull outwards from the inside of the RAM slot to release and remove the RAM.
    • The last step of this replacement guide is not required to complete the fan replacement guide.
Conclusie
Mathieu Bolduc-Clayton
518 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team S1-G5, Simcock Fall 2017 Lid van UMass Dartmouth, Team S1-G5, Simcock Fall 2017
UMASSD-SIMCOCK-F17S1G5
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 29
Altijd: 1,523
