Ga door naar hoofdinhoud
Gateway MS2285 Hard Drive Replacement
Wat je nodig hebt
  1. Gateway MS2285 Hard Drive Replacement, Turn Laptop Over: stap 1, afbeelding 1 van 1
    • Turn the laptop over so that the underside is facing towards you.
  2. Gateway MS2285 Hard Drive Replacement, Unlock The Battery: stap 2, afbeelding 1 van 2 Gateway MS2285 Hard Drive Replacement, Unlock The Battery: stap 2, afbeelding 2 van 2
    • Slide the short slider one towards the unlocked lock symbol.
  3. Gateway MS2285 Hard Drive Replacement, Release The Battery: stap 3, afbeelding 1 van 2 Gateway MS2285 Hard Drive Replacement, Release The Battery: stap 3, afbeelding 2 van 2
    • Slide the long slider towards the unlocked lock icon.
    • This slider is spring loaded and may require a little force.
    • If done correctly, a click will be heard and the battery will be slightly raised.
  4. Gateway MS2285 Hard Drive Replacement, Remove The Battery: stap 4, afbeelding 1 van 2 Gateway MS2285 Hard Drive Replacement, Remove The Battery: stap 4, afbeelding 2 van 2
    • Grasp the battery's raised end and lift upwards.
  5. Gateway MS2285 Hard Drive Replacement, Unscrew Backplate: stap 5, afbeelding 1 van 2 Gateway MS2285 Hard Drive Replacement, Unscrew Backplate: stap 5, afbeelding 2 van 2
    • Use the Phillips head screwdriver to remove the five screws holding the back plate.
    • The screws are counter-clockwise threaded.
  6. Gateway MS2285 Hard Drive Replacement, Remove Back Plate: stap 6, afbeelding 1 van 3 Gateway MS2285 Hard Drive Replacement, Remove Back Plate: stap 6, afbeelding 2 van 3 Gateway MS2285 Hard Drive Replacement, Remove Back Plate: stap 6, afbeelding 3 van 3
    • Place fingers under back plate via the indentation and lift upwards to remove.
  7. Gateway MS2285 Hard Drive Replacement, Unscrew Hard Drive Cover: stap 7, afbeelding 1 van 2 Gateway MS2285 Hard Drive Replacement, Unscrew Hard Drive Cover: stap 7, afbeelding 2 van 2
    • Unscrew the six screws holding the hard drive cover in place
  8. Gateway MS2285 Hard Drive Replacement, Unlock Hard Drive Cover and Hard Drive: stap 8, afbeelding 1 van 2 Gateway MS2285 Hard Drive Replacement, Unlock Hard Drive Cover and Hard Drive: stap 8, afbeelding 2 van 2
    • Grip onto the cover and slide it away from the connector to release the cover and hard drive.
  9. Gateway MS2285 Hard Drive Replacement, Remove Hard Drive Cover: stap 9, afbeelding 1 van 3 Gateway MS2285 Hard Drive Replacement, Remove Hard Drive Cover: stap 9, afbeelding 2 van 3 Gateway MS2285 Hard Drive Replacement, Remove Hard Drive Cover: stap 9, afbeelding 3 van 3
    • Grip onto the black plastic tab to lift the end enough to get your fingers under.
    • Once it is high enough, place another finger or fingers under the cover and lift straight off.
  10. Gateway MS2285 Hard Drive Replacement, Remove Hard Drive: stap 10, afbeelding 1 van 2 Gateway MS2285 Hard Drive Replacement, Remove Hard Drive: stap 10, afbeelding 2 van 2
    • Use hand to grab hard drive and remove.
    • Do not touch the gold connectors.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Chris mello
331 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 1-7, Shastany Fall 2014 Lid van UMass Dartmouth, Team 1-7, Shastany Fall 2014
UMASSD-SHASTANY-F14S1G7
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 14
Altijd: 3,694
