Ga door naar hoofdinhoud
Gateway MD2614u Battery Replacement
  1. Gateway MD2614u Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Ensure the laptop is completely powered off and disconnected from any power source. Turn your Gateway MD2614U laptop over as shown in the image.
  2. Gateway MD2614u Battery Replacement: stap 2, afbeelding 1 van 1
    • 2. Find the laptop battery release button lock for your Gateway MD2614U laptop.
  3. Gateway MD2614u Battery Replacement: stap 3, afbeelding 1 van 1
    • Holding the laptop battery release button, gently pull your battery away from the laptop.
  4. Gateway MD2614u Battery Replacement: stap 4, afbeelding 1 van 1
    • Insert the new battery into the slot. Push the Gateway MD2614U battery towards the laptop and secure it in place.
Conclusie
To reassemble your Gateway MD2614u laptop after replacing the battery, follow the reverse sequence of the steps you took during the initial battery assembly.
Toni Pipes
333 Reputatie
7 handleidingen geschreven
Cal Poly, Team 21-31, Regan Fall 2010 Lid van Cal Poly, Team 21-31, Regan Fall 2010
CPSU-REGAN-F10S21G31
4 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 6
Altijd: 3,884
