Ga door naar hoofdinhoud
Gateway MA7 CD/DVD Drive Replacement
Wat je nodig hebt
  1. Gateway MA7 CD/DVD Drive Replacement, CD/DVD Drive: stap 1, afbeelding 1 van 1
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Push the locking tab over to the right away from the battery to unlock it from the laptop.
    • Hold the additional locking tab to the left while puling out the battery.
  2. Gateway MA7 CD/DVD Drive Replacement: stap 2, afbeelding 1 van 2 Gateway MA7 CD/DVD Drive Replacement: stap 2, afbeelding 2 van 2
    • Remove the following screws securing the plastic panel from the bottom of the laptop:
    • Remove the seven 6 mm screws with a Phillips #0 screwdriver
  3. Gateway MA7 CD/DVD Drive Replacement: stap 3, afbeelding 1 van 3 Gateway MA7 CD/DVD Drive Replacement: stap 3, afbeelding 2 van 3 Gateway MA7 CD/DVD Drive Replacement: stap 3, afbeelding 3 van 3
    • Pull upwards on the top of the plastic panel to remove it.
    • With the exception of the screw marked "K", all of the screws will remain connected to the plastic piece.
  4. Gateway MA7 CD/DVD Drive Replacement: stap 4, afbeelding 1 van 2 Gateway MA7 CD/DVD Drive Replacement: stap 4, afbeelding 2 van 2
    • Remove the following screws holding the DVD/CD drive in place:
    • One 6 mm Phillips #0
  5. Gateway MA7 CD/DVD Drive Replacement: stap 5, afbeelding 1 van 1
    • Use the edge of a plastic opening tool to push down on the metal latch preventing the drive from being pushed out.
    • While pressing down, push the metal latch out away from the laptop.
  6. Gateway MA7 CD/DVD Drive Replacement: stap 6, afbeelding 1 van 3 Gateway MA7 CD/DVD Drive Replacement: stap 6, afbeelding 2 van 3 Gateway MA7 CD/DVD Drive Replacement: stap 6, afbeelding 3 van 3
    • Once the drive has been pried out, you can pull the CD drive out.
Conclusie
Tim Rose
392 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team S6-G2, Bernier Spring 2018 Lid van UMass Dartmouth, Team S6-G2, Bernier Spring 2018
UMASSD-BERNIER-S18S6G2
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 541
