Ga door naar hoofdinhoud
Gateway MA6 Laptop Wireless Card Replacement
Wat je nodig hebt
  1. Gateway MA6 Laptop Wireless Card Replacement, Battery: stap 1, afbeelding 1 van 1
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Make sure the switch in the upper right corner of the laptop is switched to the "unlock" position (toward the unlocked padlock icon).
  2. Gateway MA6 Laptop Wireless Card Replacement: stap 2, afbeelding 1 van 3 Gateway MA6 Laptop Wireless Card Replacement: stap 2, afbeelding 2 van 3 Gateway MA6 Laptop Wireless Card Replacement: stap 2, afbeelding 3 van 3
    • Pull the switch on the upper lefthand corner of the laptop towards the unlocked padlock icon.
    • Firmly pull the battery outwards and away from the laptop.
  3. Gateway MA6 Laptop Wireless Card Replacement, Wireless Card: stap 3, afbeelding 1 van 2 Gateway MA6 Laptop Wireless Card Replacement, Wireless Card: stap 3, afbeelding 2 van 2
    • Loosen the 3mm Phillips #0 screw from the back of the WiFi card backplate.
    • The screw will remain in the backplate.
    • Lift upwards on the back plate to remove it.
  4. Gateway MA6 Laptop Wireless Card Replacement: stap 4, afbeelding 1 van 1
    • Use the plastic opening tool to gently pry upwards on the two connecting cables to remove them.
  5. Gateway MA6 Laptop Wireless Card Replacement: stap 5, afbeelding 1 van 1
    • Remove the 2 mm Phillips #0 screw.
    • The card will lift itself up 30° after the screw has been removed.
  6. Gateway MA6 Laptop Wireless Card Replacement: stap 6, afbeelding 1 van 2 Gateway MA6 Laptop Wireless Card Replacement: stap 6, afbeelding 2 van 2
    • Hold the WiFi card on both sides and pull outwards to remove it.
Conclusie
Chris Naughton
705 Reputatie
5 handleidingen geschreven
Cal Poly, Team 6-2, Forte Spring 2014 Lid van Cal Poly, Team 6-2, Forte Spring 2014
CPSU-FORTE-S14S6G2
5 Leden
20 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 9
Altijd: 713
